 Post subject: router setup
 Post Posted: Wed Jul 14, 2010 3:51 pm
hi i configure my linksys router and i'm getting connection to my router but i'm not getting on to the internet. my router setup was completed successfull
 Post subject: Re: router setup
 Post Posted: Wed Jul 14, 2010 4:53 pm
1, OK What Router??
2, What ISP?
3, How is the router connected to the ADSL or Cable?
4, What did you have for breakfast? (This question can really affect the setup, honest!)
 Post Posted: Wed Jul 14, 2010 5:33 pm
Are you connected via ethernet or wireless? Try different LAN ports too as you might have a bad one. Your WAN port might also be dead. If that's the case then your out of luck and need to buy a new router.
You should log into your router and check it's WAN/Internet IP address and make sure it is getting the correct information from your modem and that your modem is getting the correct information from your ISP.
-Evan
