Scott Mueller's Upgrading and Repairing PCs Forum • View topic - internet connection probz
 Post subject: internet connection probz
 Post Posted: Mon Sep 27, 2010 1:57 pm
when i plug in the RJ 45 cable from my dsl connection am gettin local area connection status, status connected duration 00:15.53 speed 100.0 Mbps but i'm not getting on to the internet wen i use ipconfig /all it display ip address 192.168.0.1 subnet mask 255.255.255.0
then wen i use ipconfig /release am getting
the operation failed as no adapter is in the state permissible for this operation network adapter type 1394 .net adapter
 Post subject: Re: internet connection probz
 Post Posted: Mon Sep 27, 2010 2:10 pm
the 1394 adaptor is firewire, so ignore anything to do with that!
with ipconfig/all you should get a default gateway?
Normally this is 192.168.1.1 or 192.168.0.1 (in your case it seems that is the IP assigned to your machine) 192.168.1.254 or possibly 192.168.0.254
now try entering the default gateway address in your web browser, see what you get, should be a login page for the router so try admin/password admin/admin etc to log in the router.
 Post Posted: Mon Sep 27, 2010 2:16 pm
Can't really help you until you tell us what type of modem you have (manufacturer and model). A link to the modem manual is even more helpful. Without that information we have no idea what the modem should be doing when you plug it into your system.
Also, it sounds like the status you're getting is from the firewire network rather than your ethernet card. Go to control panel>network connections and make sure you're looking at the status of your ethernet card.
Mike
 Post Posted: Mon Sep 27, 2010 4:26 pm
 Post Posted: Mon Sep 27, 2010 6:24 pm
I just wanted to know if his router could connect, i.e narrowing fault to his router, modem, or machine (not sure if he is on ADSL or CDSL (Cable DSL).....
Yes I did just make up CDSL! :)
I do agree that he should nag his ISP, after all he all need to be told to reboot the router and hold sometimes!
Andrew, you have rebooted all your kit right? :shock: :oops:
 Post Posted: Tue Sep 28, 2010 8:19 am
