Post new topic Reply to topic  [ 14 posts ]
 Post subject: Netgear cg814gcmr
 Post Posted: Tue Sep 28, 2010 6:58 pm
Hello Scott and others,
Been asked to help with a Netgear cg814gcmr, I can't find a Netgear support page for this router!
Has http://portforward.com/ been taken over? They used to have helpful guides to erm port forward routers, yet it seems to be a pay site now! Perhaps I'm on the wrong site?
****Note that I think that site might be a scam, so prolly will try to give you Malwares***
 Post subject: Re: Netgear cg814gcmr
 Post Posted: Tue Sep 28, 2010 9:02 pm
What does Netgear have to say about it? Let me know what you find out. Scott.
 Post Posted: Wed Sep 29, 2010 5:25 pm
David McMahon wrote:
....Been asked to help with a Netgear cg814gcmr, I can't find a Netgear support page for this router!....
This would make me not want to buy from Netgear. I actually found this router for sale in one of their 2009 business brochures.
Still traces on their forum.
Last edited by FascistNation on Thu Sep 30, 2010 11:25 pm, edited 1 time in total.
 Post Posted: Wed Sep 29, 2010 5:35 pm
Is that End Of Life link you posted correct? I was greeted with "Page Not Found"...
Evan
 Post Posted: Wed Sep 29, 2010 6:50 pm
http://www.netgear.com/eol
Just to rub the salt in the CG814GCMR is at the top!
I know of at least *1* router still in use, so why on earth has support been pulled? :twisted:
I also assumed that business class equipment had a longer support life than mere "consumer" equipment!
 Post Posted: Wed Sep 29, 2010 9:25 pm
Looks like it's time for a new router. A new one will cost less than the time wasted in trying to support one that isn't supported by the manufacturer. I've had good results with Linksys and D-Link myself. Currently I've been recommending the DIR-655. Scott.
 Post Posted: Wed Sep 29, 2010 10:23 pm
Do you have a particular type of network you employ that particular D-Link in? I'm just wondering if you've found it to serve the small business customers or home users (or both) specifically. In my experience there is never a "universal" solution. Perhaps it is just the best "bang for the buck"?
Evan
 Post Posted: Wed Sep 29, 2010 11:09 pm
I'm just wondering if you've found it to server the small business customers or home users (or both) specifically.
Both of those. Almost nothing is universal, but this one is pretty close (for now). Scott.
 Post Posted: Wed Sep 29, 2010 11:15 pm
Until we start seeing a copious amount of *true* 802.11n certified (not *draft* versions) routers? Even better if they are "affordable". <g>
Evan
 Post Posted: Wed Sep 29, 2010 11:38 pm
All I can say (from experience) is that right now the two most important things in an "n" router/access point is that it *doesn't* support 5GHz operation, and that it *does* have a gigabit WAN port. YMMV <g> Scott.
PS: If you have an internet connection of faster than 25Mbps, make sure your modem also has a gigabit WAN port...
 Post Posted: Thu Sep 30, 2010 12:01 am
...is that it *doesn't* support 5GHz operation...
What's wrong with 5GHz?
...it *does* have a gigabit WAN port
Agreed, I wouldn't recommend anything else for a *new* purchase.
Another great point...that I've now made a mental note (and bookmark) of. It sounds like I need I need to double check what I pay my ISP for and what www.SpeedTest.net reports.
Evan
 Post Posted: Thu Sep 30, 2010 6:37 am
I've been using the D-Link Dir 655 for about 2 years now. It has served me well.
 Post Posted: Thu Sep 30, 2010 10:52 am
I'm sure this will change in the future, but so far I haven't yet found a dual-band router that doesn't have problems maintaining a stable connection with a dual-band card. When in 5GHz range, the connection seems to constantly switch speeds and/or even bands, causing momentary bursts and lags which are unacceptable. Also the range using the 5GHz band is so bad it basically works only in the same room as the access point. None of this occurs when restricting the connection to only the 2.4GHz band. Because of this, I currently recommend single-band "n" routers (which means 2.4GHz), and prefer those with three external antennas for maximum range and performance. If or when dual-band router technology is perfected, I'll change my recommendation. <g> Scott.
 Post Posted: Thu Sep 30, 2010 11:26 pm
Evan
Thanks, fixed.
