 Post subject: Port Forward issue.
 Post Posted: Fri Jan 06, 2012 3:38 am
My Nephew want to play Minecraft Mulitplayer make a family Multiplayer Server. Which I never done before.
I done basic how to guide from Minecraft server wiki site http://www.minecraftwiki.net/wiki/Talk: ... p_a_server One from Portforward.com and a few how to video on setup a minecraft server Basicly it the same as wiki site. Done the basic Disabled firewall.
My routher is N600 DB Wireless Dual-Band N+ Router. Which is also setup for Minecraft. From wiki or any how to video. My 3 laptop computers have Windows 7.
But what get me stuck is Port 25565 is a issue. When I check if it Open from http://portforward.com/ and http://www.yougetsignal.com/tools/open-ports/ They both Pick up my External IP Address.
Portforward.com software shows IP. List the port number 25565 for minecraft. Ping Results you where not able to ping your router. Port check Results Your port is not Open or not Reachable.
Younetsignal shows No open ports found. even on the most common Ports Like
21 FTP, 22 SSH, 23 TELNET, 25 SMTP, 53 DNS, 80 HTTP, 110 POP3.
I do have internet connection. I just feel network dumb right now lol.
 Post subject: Re: Port Forward issue.
 Post Posted: Fri Jan 06, 2012 1:03 pm
It sounds like you've done everything correctly regarding the port forwarding. If the desired port is still blocked, then you may have an issue with your ISP blocking the port. Since this is primarily Minecraft related (and we don't support that here), I recommend you take up the issue on a Minecraft forum (where I see others are having the same problem). Let me know what the problem and solution turns out to be. Scott.
 Post Posted: Fri Jan 06, 2012 3:54 pm
Hay Thank you Scott
I was just making sure I did not miss anything on hardware part of the issue. Like a setting that was not on wiki or any of the videos. That was the part I was asking about.
