Scott Mueller's Upgrading and Repairing PCs Forum • View topic - 2012 DOCSIS 3.0 Modem Recommendation
 Post subject: 2012 DOCSIS 3.0 Modem Recommendation
 Post Posted: Sun Jan 29, 2012 8:59 pm
Would you recommend the for a new DOCSIS 3.0 modem purchase?
Evan
 Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation
 Post Posted: Sun Jan 29, 2012 9:30 pm
If it has a then yes, else no. Scott.
 Post Posted: Mon Jan 30, 2012 8:54 am
Yes, . Do you still recommend the D-Link ?
Evan
 Post Posted: Mon Jan 30, 2012 9:18 am
So far, but I'm also looking into others that can run simultaneous 2.4GHz/5GHz dual-band, with separate SSIDs for each band. Other things I look for in a router/switch/access point combo include three (or more) external detachable antennas using standard connectors, gigabit Ethernet for both LAN and WAN connections, management via built-in web pages (vs. proprietary software), "guest" network capability, ports in the back/LEDs in the front, stackable shape, and powered by 12V DC with a standard barrel connector. Scott.
 Post Posted: Mon Jan 30, 2012 11:32 am
 Post Posted: Mon Jan 30, 2012 11:48 am
 Post Posted: Mon Jan 30, 2012 4:09 pm
 Post Posted: Thu May 31, 2012 7:17 pm
I've been looking for a new router. This seems to fit the bill as per your specifications above. Please tell me if I've missed anything and if this is one you would recommend. Thanks!
-Brad
 Post Posted: Thu May 31, 2012 9:10 pm
I think I would recommend it, but I haven't tested it personally. I do think it would the next one I try if any of my current routers go down. Let me know what you think if you try it. Scott.
