Author |
Evan
Post subject: 2012 DOCSIS 3.0 Modem Recommendation Posted: Sun Jan 29, 2012 8:59 pm |
Joined: Wed Mar 18, 2009 12:48 pm Posts: 405 Location: USA
Scott Would you recommend the Motorola SB6121 for a new DOCSIS 3.0 modem purchase? Evan
Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation Posted: Sun Jan 29, 2012 9:30 pm |
Site Admin |
Evan
Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation Posted: Mon Jan 30, 2012 8:54 am |
Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation Posted: Mon Jan 30, 2012 9:18 am |
Site Admin |
So far, but I'm also looking into others that can run simultaneous 2.4GHz/5GHz dual-band, with separate SSIDs for each band. Other things I look for in a router/switch/access point combo include three (or more) external detachable antennas using standard connectors, gigabit Ethernet for both LAN and WAN connections, management via built-in web pages (vs. proprietary software), "guest" network capability, ports in the back/LEDs in the front, stackable shape, and powered by 12V DC with a standard barrel connector. Scott.
Evan
Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation Posted: Mon Jan 30, 2012 11:32 am |
Are there any dual band-routers that look promising? Last I heard, you still didn't recommend them. Scott wrote: Other things I look for in a router/switch/access point combo include... Sounds like you're describing an updated version of the WRT54G. Those are still very reliable routers if you can load them with custom firmware ( DD-WRT or Tomato). Evan
Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation Posted: Mon Jan 30, 2012 11:48 am |
Site Admin |
Quote: Are there any dual band-routers that look promising? Last I heard, you still didn't recommend them. That was before "simultaneous dual-band" versions became available. This allows for two distinctly separate wireless access points (each with a unique SSID and on a separate band) to function within the same unit. With that type of design you can set systems use one or the other without random jumping between bands. Quote: Sounds like you're describing an updated version of the WRT54G. Those are still very reliable routers if you can load them with custom firmware ( DD-WRT or Tomato). I was extremely fond of the WRT54G family for many years, and while I still have several around for testing and/or temporary use, they no longer meet most of my requirements and would severely limit throughput on >25Mbps broadband connections. Scott.
Evan
Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation Posted: Mon Jan 30, 2012 4:09 pm |
Scott wrote: ... they would severely limit throughput on >25Mbps broadband connections. That is exactly why I'm upgrading the modem and router. Evan
Brad
Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation Posted: Thu May 31, 2012 7:17 pm |
Joined: Thu Mar 08, 2007 3:11 pm Posts: 127 Location: Ohio
Hi Scott, I've been looking for a new router. This D-Link DIR-835 seems to fit the bill as per your specifications above. Please tell me if I've missed anything and if this is one you would recommend. Thanks! -Brad
Post subject: Re: 2012 DOCSIS 3.0 Modem Recommendation Posted: Thu May 31, 2012 9:10 pm |
Site Admin |
I think I would recommend it, but I haven't tested it personally. I do think it would the next one I try if any of my current routers go down. Let me know what you think if you try it. Scott.
