 Post subject: BayStack 252 10.100 24-Port Hub - Software?
 Post Posted: Sat Feb 22, 2014 1:19 am
I have in my hardware stash, a BayStack 252 24 port hub.
The documentation I have found states these are managed by "web based software", but, from everything I have been able to determine, it is software that you have to install on a local machine on the network.
The problem is, I cannot find this software, and would like very much to use this software.
This is a Nortel product, but, I couldn't find anything on their site either.
Thanks in advance if someone can point me to this software, or a way to manage this hub.
 Post subject: Re: BayStack 252 10.100 24-Port Hub - Software?
 Post Posted: Sat Feb 22, 2014 12:21 pm
According to what I read here it states "When the BayStack 252 hub is in a managed hub stack, it is referred to as a "slave" because it is managed through a connection to a Baystack 250 or 253 hub. The BayStack 252 hub can also function as an unmanaged hub in a network." To me that implies that it will not work as a managed hub alone.
Another issue is that it is a hub, not a switch. I would not want a hub on a modern network as it would limit throughput and performance for any connected devices. The cheapest switch would outperform it, and in addition would save a lot on power consumption. Scott.
