 Post subject: Dial up
 Post Posted: Tue Sep 22, 2015 4:40 pm
Hello
I have a customer who wants to remain on dial up
I purchased them a new PC with windows 7 Pro
I have a USB fax modem with a Conexant chipset.
I let windows find the driver and it installed.
The connection works and authenticates and registers but no internet.
By the clock the network Icon has a yellow triangle over it, even when the connection is established.
Sometimes the yellow triangle disappears straight away and the internet works, but mostly I have to connect and disconnect the connection a couple of times for it to connect intitally.
On the times that the connection is established it does stay connected so the issue is when the connection is first established.
I thought it might be the driver so I installed the one on the CD disk but same problem
Its the yellow triangle that's stopping getting the internet, the connection itself works fine.
I did enter the DNS's for the ISP Vodafone, manually and tried the device on another pc.
I can use the same dial number at a different location and the same problem occurs there
I also tried another modem, but same problem.
Ford
 Post subject: Re: Dial up
 Post Posted: Tue Sep 22, 2015 6:04 pm
This sounds like a problem at the ISP. I would contact them for more information. Let me know what you find, Scott.
 Post Posted: Wed Sep 23, 2015 10:40 pm
Hello
I think that is my next step.
The customer advised that sometimes the same thing happened with her previous machine. If it didn't connect she would try again later and then it would connect.
Not sure why takes a couple of goes to establish the initial connection
 Post subject: Re: Dial up - update
 Post Posted: Wed Oct 21, 2015 3:37 pm
I spoke with Vodafone who advised that the dialup network is degrading over time and its normal for it not to connect sometimes.
