 Post subject: Equivalent Keys Combination for Laptop Break Key
 Post Posted: Wed May 31, 2017 2:50 pm
Dear Sir,
I have tried different suggested laptop key combinations to produce the same
effect that the Laptop Break Key has. I have used Ctrl+Fn+B, Fn+B etc to no avail.
I actually wanted to implement the password recovery procedure for my Cisco
881-k9 Router which either says Authentication Failed or Access denied each time I
tried to login in to the Router using either Serial Console Connection or SSH/Telnet
Connection respectively.
Sir, what are the Standard Laptop Break Key Equivalent Key Combinations for the ZED AIR PRO I-Life
Laptop Keyboard with 81 Keyboard Keys? Or What Laptop Manual whose name I don't
know usually contain this Information?
Thank you Sir.
Olakunle Olafiranye.
 Post subject: Re: Equivalent Keys Combination for Laptop Break Key
 Post Posted: Wed May 31, 2017 5:33 pm
All of my ThinkPad laptops have a dedicated Pause/Break key but I know that many other laptops do not. The most common substitution for Ctrl-Break is Ctrl-C, but if that doesn't work you can try the other key combinations shown here: https://en.wikipedia.org/wiki/Break_key
If none of those work then I would recommend connecting an external keyboard that has a Pause/Break key. Let me know what solves the problem, Scott.
 Post Posted: Sun Jun 11, 2017 10:45 pm
Dear Scott,
With help from different sources, the Ctrl + Fn + Pause Keys Combination solved the Problem Sir.
Olakunle.
 Post Posted: Mon Jun 12, 2017 12:21 am
I'm glad you solved the problem, thanks for letting me know, Scott.
