Scott on my wifes old PC I have an . I'm trying to figure out how to disable the PXE BOOT. I changed network boot to the last option on the boot order in Cmos. However I still get the PXE boot screen for a few short seconds.
I've downloaded and ran the utility,
https://www.intel.com/content/www/us/en ... ducts.htmlFrom the command prompt in the correct directory I type,
"BOOTUTILW64E -BOOTENABLE=DISABLED -ALL"
I get the error,
"Found discrete rom in the flash for NIC 1.
The -BOOTENABLE command can only be used on flashed combo images."
Here is a description of the commands. I just want to disable PXE so POST doesn't look for it.
