Author |
Kit Emma
Post subject: Client PCs on LAN are not displaying sites Posted: Tue Mar 18, 2008 11:06 pm |
Post subject: Posted: Wed Mar 19, 2008 7:45 am |
Site Admin |
If you are using ICS (Internet Connection Sharing), then that is likely the cause of your problems. I recommend you set up your network using a router instead, which should eliminate those types of problems. Scott.
Mike
Post subject: Posted: Wed Mar 19, 2008 7:51 am |
Site Admin |
Kit Emma
Post subject: Posted: Wed Mar 19, 2008 9:23 am |
Thanks.
It sounds though there is no fix to this glitch than replacing it with a Router. I've tried to walk through the Network troubleshooter of xp for Internet Connection Sharing (ICS). All the solutions did not apply to this glitch. At last, restoring the system to an earlier date on the host computer crossed my mind. I decided to do that and guess what! The client PCs were able to load all the websites that didn't load first. I did remember the kind of optimization I carried out few days ago using "TuneUp System Optimizer" for Tuneup Utilities 2007 under "Accelerate downloads and Internet surfing." which might have affected ICS.
I've taken the recommendation for an upgrade to a Router. Thanks.
-- Kit
Post subject: Posted: Wed Mar 19, 2008 10:15 am |
Site Admin |
Kit Emma
Post subject: Posted: Wed Mar 19, 2008 11:08 am |
Post subject: Posted: Wed Mar 19, 2008 11:14 am |
Site Admin |
Kit Emma
Post subject: Posted: Wed Mar 19, 2008 11:34 am |
Post subject: Posted: Wed Mar 19, 2008 11:44 am |
Site Admin |
Kit Emma
Post subject: Posted: Wed Mar 19, 2008 12:36 pm |
