Author |
paulgj
Post subject: Recommend gigabit switch? Posted: Tue Jul 01, 2008 11:05 am |
Joined: Tue Jun 10, 2008 7:44 pm Posts: 361 Location: Bellevue, WA, USA
I am in the market for a Gigabit switch and was wondering if you recommend one or are they all pretty much the same nowadays? I already have a netgear router if that makes any difference. All my PC's have or will have gigabit NICs.
Thanks!
Post subject: Re: Recommend gigabit switch? Posted: Tue Jul 01, 2008 11:37 am |
Site Admin |
There doesn't seem to be much difference between them these days. Just be sure you are looking at switches that feature gigabit on all ports, not just on uplinks. I do recommend newer designs as some of the earlier gigabit switches ran hot. These days I recommend most of the name brands including 3Com, D-Link, Linksys, NetGear, and SMC. The biggest choices are the number of ports, and whether you want them front or rear mounted: http://tinyurl.com/5zxpqoScott.
paulgj
Post subject: Re: Recommend gigabit switch? Posted: Tue Jul 01, 2008 12:03 pm |
Post subject: Re: Recommend gigabit switch? Posted: Tue Jul 01, 2008 12:18 pm |
Site Admin |
That looks like a great choice! How about posting the promo code so others might get the same deal? <g> Scott.
paulgj
Post subject: Re: Recommend gigabit switch? Posted: Tue Jul 01, 2008 12:21 pm |
Yes, I forgot to do that. Here's the main offers page including the switch: http://tinyurl.com/4e4byxPromo code for the switch: EMCAHABCC They also have an offer on the PC Power & Cooling 610 PSU
Post subject: Re: Recommend gigabit switch? Posted: Tue Jul 01, 2008 12:45 pm |
Site Admin |
Thanks for posting that code and the link. $80 for the PCP&C Silencer 610 is an excellent deal, a total of $35 off combining the $10 promo code and a $25 rebate. Hopefully anybody seeing this who needs a high quality PSU will click on that link and take advantage of that deal... Scott.
paulgj
Post subject: Re: Recommend gigabit switch? Posted: Tue Jul 01, 2008 12:48 pm |
Definitely a good deal, I got the 750 Silencer through a similar deal for $99 after promo code and rebate although I'm pretty sure that code has expired.
