Scott Mueller's Upgrading and Repairing PCs Forum • View topic - A *better* way to power off your systems...
 Post subject: A *better* way to power off your systems...
 Post Posted: Wed Jun 20, 2007 6:25 pm
 Post subject: Re: A *better* way to power off your systems...
 Post Posted: Thu Aug 26, 2010 11:23 am
After I read this post, I have a couple of questions. Would the hibernate under the normal shut down options use the same wattage as the hibernation (ACPI S4) you described? Are they the same power down mode or is it a totally different?
George
 Post Posted: Thu Aug 26, 2010 1:34 pm
ACPI S4, Suspend To Disk, and Hibernate are all just different names for exactly the same thing, that is they are the same system state. Scott.
 Post Posted: Thu Aug 26, 2010 2:08 pm
Thanks for the quick reply and for answering even a simple newbie question like mine.
George
 Post Posted: Thu Jan 06, 2011 10:29 pm
In windows 7 power options there is a "change what power buttons do" if i set the power button to hibernate will it have the same effect as what your describing?
 Post Posted: Fri Jan 07, 2011 1:42 am
Yes. Scott.
 Post Posted: Fri Jan 07, 2011 7:42 am
ok great thanks for the prompt response
 Post Posted: Fri Jan 14, 2011 10:37 pm
Is never shutting down a PC completely a bad idea when it doesn't have any RAID- or Enterprise-class hard drives?
 Post Posted: Fri Jan 14, 2011 11:08 pm
Not necessarily. Scott.
