 Post subject: Server Dead NO Power
 Post Posted: Sat Sep 03, 2011 9:56 am
Working on a Dell Power Edge SC440 wont turn on! The light on the Motherboard comes on.
Things I have checked.
1. Switch Power Supply with a known good one
2. Boot Strap Unplug everything except power to the board (1) stick of memory
3. Switched the CPU
Is there a way to start this server without the i/o panel assembly, like on a regular
PC Mother board were we can jump the board with a small screw driver?
I have it diagnosed too the i/o panel switch or the motherboard, the problem is I don't have a spare i/o panel to test. Is there anyway to by pass the switch any trick you may know.
Thanks, Craig
 Post subject: Re: Server Dead NO Power
 Post Posted: Sat Sep 03, 2011 10:34 am
Working on a Dell Power Edge SC440...
You know the drill.
Is there a way to start this server without the i/o panel assembly...?
Yes, with a paperclip. Let me know what the problem turns out to be. Scott.
 Post Posted: Sat Sep 03, 2011 11:29 am
Sorry, but are you saying put or probe the ribbon cable connecter on the motherboard?
If so are you jumping across two pins or farther apart pins? I ve never jump one these boards. Can you tell where and how to use the paper clip?
Thanks Craig
 Post Posted: Sat Sep 03, 2011 3:17 pm
Scott wrote:
You know the drill.
 Post Posted: Sun Sep 04, 2011 8:47 pm
Well put the paper clip in the power connector and the power supply and cpu fans turns on but no video. I unplugged the front power switch and case switch before connecting the paper clip. The led light on the motherboard light amber. I was reading if I take out
all memory modules that in the system it should beep consantly and if it doesn't the the motherboard is bad is that true with all motherboards? If the motherboard is shorted
by way of cold solder joints, what's your thought on heating the board and the videochip
see if that revives it. We fix HP DV2000-9000 video reflow the chip with heat gun all the time works 90% of the time. Whats your thought on trying to reheat the motherboard?
I am thinking the motherboard is shorted but not sure were
Thanks, Craig
 Post Posted: Sun Sep 04, 2011 9:23 pm
I was reading if I take out all memory modules that in the system it should beep consantly and if it doesn't the the motherboard is bad...
Where did you read that? Scott.
 Post Posted: Tue Sep 06, 2011 4:15 pm
Power Edge SC 440
Sevice Tag: J7208F1
Express: 41786710813
MotherBoard: CN:0NY776-70821-7AH-5051
I read about the memory left out of the computer and if it doesnt beep then its bad
on a forum I dont remember which one, it didnt sound right to me. I never remember
you talking about that happening with memory.
 Post Posted: Thu Sep 08, 2011 9:35 am
OK, *now* we're getting somewhere. <g> According to the Service Tag number you provided, that system is an OptiPlex 745 that was originally sold in Brazil.
I'm not sure where you are located, but most of Brazil uses 220/240VAC power. If you are using 110/120VAC, you may need to change the input voltage switch on the PSU to the 110/120VAC setting. An improper setting would result in *exactly* the symptoms you are describing.
If the PSU input switch is set correctly and the system still doesn't work, then what are the status of the diagnostic LEDs on the motherboard?
Note that with no memory installed, according to the diagnostic beep codes for that specific system, it will beep in a 1-3-1 through 2-4-4 pattern.
Let me know what you find, Scott.
 Post Posted: Mon Sep 12, 2011 3:11 pm
Sorry Scott,
I type the wrong tag it's J72Q8F1. The power supply is set right 115v and it test good
I also tried a good know power supply still no power. When I used the paper clip to jump the board the fans in the power suppy and the cpu fan turn on and the yellow light on the motherboard. We tried new PSU and same results also switch the cpu with several different ones same no power. Pull the motherboard out of the case and tested still no power when we jump the power just the fans turn on and the motherboard light. Plus I didnt hookup the hard drive or the optical drive while testing and used 1 stick of memory
to check and switched thru all memory sticks one at a time and tried different slots.
What do you think motherboard bad?
Thanks, Craig
 Post Posted: Tue Sep 13, 2011 9:13 am
Craig,
When Scott continually asks for links, this is what he is looking for:
Here is a link to my PowerEdge SC440:
http://support.dell.com/support/downloa ... ag=J72Q8F1
Or, you can embed the link like this:
With links like that, Scott is more inclined to delve deeper into answering since he doesn't have to do the legwork to find your system specs.
Mike
 Post Posted: Tue Sep 13, 2011 1:53 pm
