 Post subject: New setup forgot wireless was enabled!
 Post Posted: Fri Jul 05, 2013 8:23 pm
Hey Scott, I just moved into a new apartment building in a city/urban area. While I was configuring my dir655 router I forgot that wireless is enabled by default!. I let it go like that for around 3-4 hours. I've since re-set the router to default, disabled wireless, enabled user and admin passwords, and set up open dns. I looked before I disabled and saw about 6 other lan connections, mostly android devices. I don't believe I have anything files or folders shared on the pc. Do I have anything to worry about?. I also did a full super antispyware scan and it just found cookies. Of course I have the normal windows firewall enabled. This is windows 7 pro pc.....
 Post subject: Re: New setup forgot wireless was enabled!
 Post Posted: Fri Jul 05, 2013 8:25 pm
Should I be worried?
 Post Posted: Fri Jul 05, 2013 8:30 pm
Oh I did find one shared folder that just has some A+ stuff on it. They would also need my password to get into the file though right?. I would think most of the people "piggybacking" were just there to get some internet access real quick.
 Post Posted: Fri Jul 05, 2013 8:32 pm
It sounds like a few cellphones were using your wireless for an hour or so. As long as it is secure now I wouldn't be worried. Scott.
 Post Posted: Fri Jul 05, 2013 8:35 pm
This cable internet seems much faster than my DSL I had at my old place, even though the DSL was supposedly 20 Mbps down. I'm paying for 15Mbps down with Time Warner and it just seems much much faster.
 Post Posted: Thu Jul 18, 2013 9:07 pm
Even though you are paying for less download speed you could be getting better speeds if any of the equipment operated by the previous ISP was working properly. Assuming you were using the same router before, you might have a better modem or even the cables before or after the demarcation point could be an issue. I've had all of those issues happen myself, all at the same house with the same ISP.
Evan
