 Post subject: Thinkpad R500 stuck on splashscreen
 Post Posted: Tue Dec 03, 2013 9:04 pm
So I've got a Thinkpad R500 that upon startup does nothing once it gets to the Thinkpad splash screen, it just stays there. I removed the battery, optical drive, hard drive and memory and it still just stops there. I tried both memory sticks separately in each slot and still nothing. There's no access to the BIOS or anything.
Any ideas?
Thanks,
Mike
 Post subject: Re: Thinkpad R500 stuck on splashscreen
 Post Posted: Tue Dec 03, 2013 9:18 pm
Scratch that question. Broken USB port and a pin was shorted.
Damned kids!!!
http://forums.lenovo.com/t5/R-L-Series- ... a-p/301526
Mike
 Post Posted: Tue Dec 03, 2013 10:21 pm
Keep those kids away from the USB ports! <g> Scott.
PS: The physical design of the standard USB port is incredibly bad, especially for something so widely used. It is not properly keyed such that it easily allows for upside-down connection attempts, which often results in connector damage.
 Post Posted: Tue Dec 03, 2013 11:29 pm
I like the USB-B male connector into the Ethernet port, myself. Hey, they feel the same when you are working under a desk, feeling for the port on the back. It fits marvelously! If only it worked marvelously, or the Ethernet port worked at all.
 Post Posted: Tue Dec 03, 2013 11:33 pm
Mike, I wonder if you were able to straighten the pins out, or I wonder if that port is on a (replaceable) daughter-board inside the Laptop?
 Post Posted: Wed Dec 04, 2013 7:43 pm
Scott wrote:
....The physical design of the standard USB port is incredibly bad, especially for something so widely used. It is not properly keyed such that it easily allows for upside-down connection attempts, which often results in connector damage.
Ask and ye shall receive.
Of course, it is not backward compatible with any prior standard. . .
and we really haven't designed it yet but rest assured it is more than vaporware. And we will release it a week before USB4.
 Post Posted: Wed Dec 04, 2013 9:24 pm
Bent pins so they weren't shorting out and computer works fine. a piece of electrical tape over that port to block usage and hopefully it's "fixed"
Mike
