 Post subject: Only Win10 will support newer CPUs
 Post Posted: Sun Jan 17, 2016 1:14 pm
New MS policy: Win7 and 8.1 will no longer support newer CPUs. Combined with ending all support for Win8 (ala XP) last week MS is kicking sand in the faces of its users. Upgrade to Win10 or else....bitches. Where ya gonna go?
Windows 10 Embracing Silicon Innovation
https://blogs.windows.com/windowsexperi ... nnovation/
 Post subject: Re: Only Win10 will support newer CPUs
 Post Posted: Mon Jan 18, 2016 7:55 pm
Scott, are you particularly frustrated over Microsoft's plans?
 Post Posted: Mon Jan 18, 2016 8:56 pm
It is very frustrating to see Microsoft seem to do everything in its power in what appears to be an attempt to kill the PC. If it isn't intentional then it may be ignorance. Scott.
 Post Posted: Tue Jan 19, 2016 2:01 pm
Why do you think Microsoft would want to kill the PC, Scott? Would you still recommend the GWX Control Panel? BTW, at least some users can breathe a sigh of relief. This piece is also worth checking out.
 Post Posted: Tue Jan 19, 2016 3:37 pm
In this case I believe Hanlon's Razor applies. So while that may not be the intent the end result seems to be the same.
Yes indeed. Scott.
Users browsing this forum: Bing [Bot] and 7 guests
