Scott Mueller's Upgrading and Repairing PCs Forum • View topic - system won't shut down
 Post subject: system won't shut down
 Post Posted: Mon Nov 09, 2015 3:07 pm
Hi Scott. I am working on hp635,320Gb/2Gb,Windows 7,AMD E-300,1.30GHz300,1.30ghz. The system won't shut down except by holding down the power button. If you click on the shut down button, the screen goes off but power LED is still on and fan still working. I tried system restore but didn't work. Pls I need help. Thanks in advance.
 Post subject: Re: system won't shut down
 Post Posted: Mon Nov 09, 2015 8:15 pm
I would first try a hard reset: http://h20565.www2.hp.com/hpsc/doc/publ ... cale=en_US
If that doesn't help then I would install (or reinstall) the latest power management software: http://h20564.www2.hp.com/hpsc/swd/publ ... nvOid=4059
If none of that helps then I would test to see if the problem was hardware or software by installing a temporary drive with a new clean install of Windows, drivers and power management software. If that doesn't solve the problem then most likely it is due to defective hardware. Scott.
 Post Posted: Mon Nov 09, 2015 10:36 pm
Alright man. Thanks a million times. I will let you know how it goes.
 Post Posted: Wed Nov 11, 2015 8:14 am
Hi Scott, I tried the above procedures but to no avail. I am thinking of installing a fresh copy of Windows. I will really appreciate more information. Thanks.
 Post Posted: Sat Nov 14, 2015 9:57 am
If it worked properly when booting from a temporarily installed HDD with a fresh copy of Windows and drivers then that would suggest the original software was at fault. If not then that would suggest it might be hardware. If you suspect hardware I would test the system with the battery removed. I would also try clearing the CMOS RAM (BIOS Setup info). There should be an option to reset to defaults in the BIOS Setup or you can remove the RTC (Real Time Clock, aka CMOS battery). Unfortunately according to the to get to that battery you have to remove just about everything from the system including the motherboard. Hopefully it is just a software issue that a reload will solve. Scott.
 Post Posted: Sat Jan 23, 2016 12:12 am
