 Post subject: Installing updates for Windows 7 after clean install of OS
 Post Posted: Mon Jan 25, 2016 4:58 pm
Scott, I've been having trouble installing updates for Windows 7 Professional after doing clean installations of the operating system. It too often seems to take forever for the Windows Update function to find updates, and I am clearly not alone in having the problem. There have been a couple times where 152 updates for my OS were found, but installing at least the vast majority of those updates went awry after I restarted the desktop PC with the Windows 7 installation. Scott, do you know of a particularly efficient way to install updates for Windows 7 at the present time?
 Post subject: Re: Installing updates for Windows 7 after clean install of
 Post Posted: Mon Jan 25, 2016 9:32 pm
The best way to install updates on a new OS installation is to integrate them into the install media: https://www.raymond.cc/blog/create-an-i ... tall-disc/
Installing hundreds of updates via Windows or Microsoft Update can take a while and require many restarts during the process. Scott.
 Post Posted: Tue Jan 26, 2016 9:47 pm
Scott, I've used Windows Updates Downloader and NTLite to create a Windows 7 Professional installation disc. A whole bunch of security-related patches were integrated, but Internet Explorer 11 was curiously not. I used the custom installation disc for my present installation of Windows 7 Pro on my usual desktop PC. When I try to install Internet Explorer 11, however, the Internext Explorer 11 Setup utility ceases to work. Below is the problem signature:
Problem Event Name: BEX
Application Name: IE11-Windows6.1.exe
Application Version: 11.0.9600.16428
Application Timestamp: 525b8b98
Fault Module Name: StackHash_0a9e
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: d50a6761
Exception Code: c0000005
Exception Data: 00000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Scott, can you help me understand what's going on? Be glad that I used a DVD-RW for my custom installation disc.
 Post Posted: Tue Jan 26, 2016 11:47 pm
Unfortunately I don't support NTLite, for any questions about that I recommend you seek support from the author. Scott.
 Post Posted: Wed Jan 27, 2016 9:16 am
Well, Scott, can you interpret the problem signature for me?
 Post Posted: Wed Jan 27, 2016 12:20 pm
Does the IE install work on a clean Windows 7 load? If so then the problem would appear to be related to your NTLite based installation. In that case I recommend contacting NTLite for support. Let me know what you find. Scott.
 Post Posted: Wed Jan 27, 2016 12:45 pm
With the installation that was created with my custom disc, I was able to install Internet Explorer 11 and various other things via Windows Update.
 Post Posted: Thu Jan 28, 2016 1:53 pm
lol, isn't that what slipstreaming is to avoid?!
 Post Posted: Thu Feb 11, 2016 12:50 pm
For people who choose to install Windows 7 Pro w/ SP1 using an installation disc supplied by Microsoft as opposed to a custom-built installation disc, I found some Microsoft-related pages that essentially must be read. Check out the following links:
https://support.microsoft.com/en-us/kb/3102810
https://social.technet.microsoft.com/Forums/windows/en-US/6b0554c7-5045-480e-9013-80f7b0842498/how-do-i-add-a-website-to-the-windows-firewall-exceptions?forum=w7itprosecurity
