 Post subject: USB hub particularly worth recommending?
 Post Posted: Mon Mar 28, 2016 8:38 pm
Scott, is there a USB hub that you would particularly recommend?
 Post subject: Re: USB hub particularly worth recommending?
 Post Posted: Mon Mar 28, 2016 10:09 pm
I would classify that as a type of device where it doesn't really matter which one you use as long as it meets your needs. In other words. as long as it has the speed, number of ports and types of connectors you want then it should be as good as any other that matches. Scott.
 Post Posted: Tue Mar 29, 2016 10:49 am
http://www.newegg.com/Product/Product.a ... 98C3RD2636
