 Post subject: about the action center did it reaplce the security center?
 Post Posted: Sun Aug 28, 2016 9:45 pm
in windows 7 the icon action center did that replace the security center like in windows xp and windows vista icon in the control panel.
 Post subject: Re: about the action center did it reaplce the security cent
 Post Posted: Sun Aug 28, 2016 11:18 pm
Yes. Scott.
 Post Posted: Mon Aug 29, 2016 4:24 am
Scott wrote:
Yes. Scott.
That what I thought.
I also would like to know why in the heck when doing the windows updates takes for a long time for it to find the updates. It took me about 6 hours for the windows 7 pro to find the windows updates and then downloading them. Is Microsoft severs can't handle people doing the windows updates. I try to do the windows updates last night and I got them instill just before 5:00pm.
There is one reason I like windows 10 is that you no longer need a antivirus software so that is a plus right there.
One thing I hate about windows 10 is the auto updates there is no way to set the windows updates to check and then let me download them when I want to like windows 7 and in windows vista and in windows xp and so on.
Scott I also got your Comptia A+ cert guide book.
I found a place where to take the test
DFC Consultants, Ltd.
I got the third edition is there a 4th edition.
Thanks.
 Post Posted: Mon Aug 29, 2016 11:40 am
spiderman wrote:
I also would like to know why in the heck when doing the windows updates takes for a long time for it to find the updates...
That is unfortunately a huge problem on Microsoft's end that it seems unwilling to fix. You can see some tips and tricks to "fix" Windows Update on your own here: http://www.sevenforums.com/windows-upda ... tes-3.html
I never needed antivirus software on Windows XP or 7 either. ;)
You do have some limited control over updating on Windows 10, and the Professional Edition can be set to defer feature updates as well.
Scott I also got your Comptia A+ cert guide book...
Make sure to check what tests you are taking. The 3rd edition and prior covers the 220-801/802 tests, which were retired on June 30th 2016. There is a new edition that covers the new 220-901/902 tests. More information on the new tests here: https://certification.comptia.org/certi ... -a-900-faq
Thanks, Scott.
Users browsing this forum: Bing [Bot] and 7 guests
