Scott Mueller's Upgrading and Repairing PCs Forum • View topic - HELP - C:\windows\system32\config\system missing
Post new topic Reply to topic  [ 16 posts ]
 Post subject: HELP - C:\windows\system32\config\system missing
 Post Posted: Wed Oct 12, 2016 1:13 pm
Hi,
I know I'll need to reinstall but first need files from PC
Optiplex 780 9z9k5m1
It won't do anything with the dell CD.
I can get into setup
Please help!
 Post subject: Re: HELP - C:\windows\system32\config\system missing
 Post Posted: Wed Oct 12, 2016 1:22 pm
The best way to get the files off the drive would be to remove it and connect it to another system. It would be easiest to use a USB enclosure or dock like this: http://www.newegg.com/Product/Product.a ... B274850507
 Post Posted: Wed Oct 12, 2016 1:27 pm
I'm in canada
Can you see anything here?
http://www.staples.ca/
They deliver the next day?
 Post Posted: Wed Oct 12, 2016 1:30 pm
It ships here
Sorry this is dumb:
Do I need USB drives?
How many?
Thank you!
 Post Posted: Wed Oct 12, 2016 1:41 pm
If you have the dock, you would remove the drive from the system not booting, insert it into the dock, then plug the dock into another working system. Using the working system you could copy the files off the drive in the dock to that system or any other attached drive (such as another USB flash or hard disk drive). Scott.
 Post Posted: Wed Oct 12, 2016 2:03 pm
Hi,
I cannot log onto newegg
What on the Staples web site would I look for all is for laptop (this is a pc)
THANK YOU!
 Post Posted: Wed Oct 12, 2016 2:05 pm
continued:
Startech.Com Universal USB 3.0 Laptop Mini Docking Station with HDMI® Or VGA, Gigabit Ethernet, USB 3.0
OR
Startech.Com Travel Docking Station For Laptops, USB 3.0, VGA
OR
Startech.Com Universal USB 3.0 Laptop Mini Docking Station with VGA, Gbe, USB 3.0 Gigabit Ethernet Adapter Nic with VGA
 Post Posted: Wed Oct 12, 2016 10:03 pm
This appears to be the cheapest one at Staples in Canada: http://www.staples.ca/en/StarTech-com-U ... CA_1_20001
Not quite as nice as the one at Newegg, but it will do the job. Scott.
 Post Posted: Sun Nov 13, 2016 4:44 pm
 Post Posted: Sun Nov 13, 2016 7:33 pm
It appears that the drive is mounted in a small chassis complete with a cooling fan, it looks like an excellent design. You will find hard drive removal/replacement instructions in the "Hard Drivel" section on p. 53 of the . Scott.
 Post Posted: Mon Nov 14, 2016 12:37 am
 Post Posted: Mon Nov 14, 2016 9:45 pm
I'm trying to "pull" the drive out of the chassis but it will not move.
(The fan was really easy to remove....)
What (on the drive) is the best (SAFEST) thing to pull on?
There is a scroo midway on side with the blue tabs.
Thank you
 Post Posted: Mon Nov 14, 2016 10:23 pm
See step 13 where it says: "To release the hard drive from the cage, pull back on the blue tabs and pull forward on the hard drive. The tabs may be stiff after a few years so you may need to use some force. Scott.
 Post Posted: Tue Nov 15, 2016 2:27 pm
 Post Posted: Thu Nov 17, 2016 1:27 pm
More problems but ... You are a genius Scott!
At least I saw the files!
I got the startech enclosure which loads at the top.
It did not come with a "stand".
StarTech.com USB 3.0 to SATA Hard Drive Docking Station for 2.5/3.5 HDD
The drive got very warm. I cannot reattach the fan b/c it has no power supply. (Just plugs into the Optiplex board.)
QUESTIONS:
Was the fan attached to the drive because of the tight fit (being in a SFF box)?
Or should it be there in any computer?
Or is it normal for a drive to warm up?
If the drive normally gets warm - hot, what length of time should I copy from it?
(Who knows maybe it won't work today)
Thanks again.
 Post Posted: Fri Nov 18, 2016 11:37 am
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
