Author |
waltlip
Post subject: Windows 10 Posted: Sun Dec 18, 2016 11:35 am |
Joined: Mon Feb 23, 2009 7:41 pm Posts: 84 Location: Cinnaminson, NJ 08077
Scott, I've noticed you avoid discussing Windows 10, and recommend installing Windows 7. would you care to explain your objections to Windows 10?
Post subject: Re: Windows 10 Posted: Sun Dec 18, 2016 6:33 pm |
Site Admin |
waltlip
Post subject: Re: Windows 10 Posted: Mon Dec 19, 2016 10:47 am |
Scott, Thanks for your reply with all the pertinent posts. I am not a Tech, just an octogenarian tinkerer, so I downloaded W10 before the deadline onto an HP Elitebook 2540p with Windows 7 professional 64bit. After a bit of upgrading it is now running as fast as with W7, and I am satisfied with it. One thing I did overlook in your subsequent post was your statement about using Windows 10 with 'Classic Shell' added. I will look in to that and probably try it.
I did make a clone of the Windows 7 OS before the W10 download in the HP EB 2540P. This was Just in Case I had problems, or didn't care for W10. Your Forum is extremely helpful. WFL
Post subject: Re: Windows 10 Posted: Mon Dec 19, 2016 7:05 pm |
Site Admin |
Thanks Walt. You are wise to keep your options open by making a clone of Win7. Let me know what you think if you try the Classic Shell. Scott.
Maxirad
Post subject: Re: Windows 10 Posted: Mon Jan 16, 2017 9:06 pm |
Scott, what's wrong with not having Classic Shell for a PC with a Windows 10 installation?
Post subject: Re: Windows 10 Posted: Tue Jan 17, 2017 1:29 am |
Site Admin |
