 Post subject: How to enable Java on the Internet Explorer 11 on Windows 10
 Post Posted: Fri Jul 21, 2017 9:31 am
Dear Sir,
After enabling Java on the Internet Explorer 11 on Windows 10 as shown below:
Internet Explorer
Click Tools and then Internet Options.
Select the Security tab, and select the Custom Level button.
Scroll down to Scripting of Java applets.
Make sure the Enable radio button is checked.
Click OK to save your preference.
I still keep getting the attached error message when am running the Cisco Configuration
Professional that uses Internet Explorer only.
Please Sir, what are the issues with Internet Explorer 11 and how should enabling Java be resolved not
Only for Cisco Configuration Professional but for also other Apps that might require it Utilization later.
Thanks.
Olakunle.
 Post subject: Re: How to enable Java on the Internet Explorer 11 on Window
 Post Posted: Sat Jul 22, 2017 1:14 am
Are you running any anti-malware (anti-virus) applications? If so what happens after you disable or uninstall them? Scott.
PS: I do recommend Firefox or Chrome over IE... What happens when you use those browsers?
