Post new topic Reply to topic  [ 26 posts ]
 Post subject: electric screwdriver for laptop
 Post Posted: Thu Oct 19, 2017 7:38 pm
Electric Screwdriver 800
https://www.youtube.com/watch?v=zX2UW_B3uLE
Teardown #010: The Electric Screwdriver 800
https://www.youtube.com/watch?v=KQ5gZhdMDuY
Scott what do you think of this electric screwdriver it seems to have the small bits for a laptop screws
 Post subject: Re: electric screwdriver for laptop
 Post Posted: Thu Oct 19, 2017 11:08 pm
I don't know anything about that one. I'd want to see a link to the mfr. page including specifications, price and other detailed information, or possibly a written review (I normally won't spend time watching videos). From a quick glance it appears to be corded and for the last 30 years or so I've only used cordless models, so that is what I would recommend: https://www.amazon.com/Best-Sellers-Ind ... ial/552750
 Post Posted: Tue Oct 24, 2017 7:13 pm
Ok so I would need a bit holder for my dewalt screwdriver for small laptop screws so what would i need I guess maybe a bit hold for 1/4 that part that goes into the screwdriver and the other end would be to hold the bits of like ph1 and maybe more that size....
this is the dewalt screwdriver i have https://www.amazon.com/DEWALT-DW920K-2- ... HV3C11X83E so what bit holder would i need to hold small bits for this screwdriver screw bits of ph000 ph00 ph0 ph1 and maybe more????/????/
I went to the local stores and I can't find any bit holder with a 1/4 shaft and the other end small enough to hold those type of bits scott????
 Post Posted: Wed Oct 25, 2017 5:23 am
HERE
https://www.amazon.com/KKmoon-Electric- ... 4VN6Z6FND9
 Post Posted: Wed Oct 25, 2017 10:58 pm
I recommend Wiha bit sets: https://www.wihatools.com/bits/bit-sets
 Post Posted: Thu Oct 26, 2017 12:19 am
ok but I do have this kit
Hyper Tough Battery Powered Precision Screwdriver Set
I just looking for a 1/4 adapter to hold these bits to remove screws from the laptops with my dewalt screwdriver this is the model I have https://www.amazon.com/DEWALT-DW920K-2- ... HV3C11X83E
I have this kit but the screwdriver is to slow
https://www.walmart.com/ip/Hyper-Tough- ... t/45715100
 Post Posted: Thu Oct 26, 2017 11:53 am
spiderman wrote:
I just looking for a 1/4 adapter to hold these bits to remove screws from the laptops with my dewalt screwdriver...
They are very common and should be available at any hardware store. Here are some online: https://www.amazon.com/Best-Sellers-Hom ... 8107039011
 Post Posted: Sat Oct 28, 2017 2:24 am
You are not understanding me a 1/4 hold on the bit holder will not work with these bits. I am looking for a bit holder that has a about a 4mm hole and a shank 1/4 to fix the dewalt screwdriver.
I don't know if these one of these bit holder will fix these screw bits....
the shaft of these bits are not 1/4 so they will not fix into the dewalt screwdriver
https://www.google.com/search?q=4mm+bit ... 00&bih=769
I hate to buy something online and it don't work... and I can't find them in any hardware store. I try home depot I try ace hardware and I also try lowes and menards.
if you go to to this link
go here and you know what I am talking about the bits are smaller then 1/4
then click on here
Then let me know what you think I should do.
see below how small the end are they won't fix in a 1/4 bit adapter or in the dewalt screwdriver. so what adapter would i need to get so I can use these bits in the dewalt screwdriver.
 Post Posted: Sat Oct 28, 2017 8:17 am
If your screwdriver won't accept standard bits or bit holders then I recommend you get one that does. See my previous posts above for recommendations. Scott.
 Post Posted: Sat Oct 28, 2017 6:02 pm
What do you think of this kit
https://www.ifixit.com/Store/Tools/64-B ... F145-299-1
it has a 1/4 to 4mm adapter in this kit. I hate to buy another kit just to have this adapter so I can use it on my dewalt screwdriver.
 Post Posted: Sat Oct 28, 2017 11:37 pm
spiderman wrote:
What do you think of this kit...
I can't vouch for anything I haven't tested myself. Let me know what you think if you get it. Scott.
 Post Posted: Tue Oct 31, 2017 10:07 am
which kit do you have? for laptops.......
 Post Posted: Tue Oct 31, 2017 11:26 am
https://www.wihatools.com/tech-tools/micro-bits/micro-bit-to-1-4-drive-insert-bit-adapter
https://www.wihatools.com/tech-tools/mi ... it-adapter
would this work with the bits I have now
like this kit I have
or from harbor freight...
 Post Posted: Tue Oct 31, 2017 9:38 pm
I don't have any experience with non-standard drivers and bit sets so I don't know what would work with the bits you have now. Best to start over with more standard tools. I personally use several older Black & Decker drivers and drill/drivers with a number of different bit sets that I've accumulated over the years. Scott.
 Post Posted: Wed Nov 01, 2017 3:18 pm
I got it you saying that small laptop screws are as the same size as desktop screws am i right. What size screw-bit did you used on the upgrading and repairing laptop 2nd edition in the video when taking out the keyboard hard drive and the cd-rom drive.......
What is your version on standard tools.
I order that bit to give this company a chance. and see how things go.
weeeeeeeeeeeehaaaaaaaaaaaaaaaaaaaaaa
 Post Posted: Wed Nov 01, 2017 11:52 pm
The screws used in laptops are generally much smaller than those used in desktops.
I believe I used PH0 or PH1 bits, probably from Wiha. I thought you were talking about the end of the bit that fits into the tool vs. the end that fits into the screw. In that case using standard bits means they fit in the standard tools. The screw heads vary among laptops so you need to use the correct sized bit to fit the screw you are trying to remove. Scott.
 Post Posted: Thu Nov 02, 2017 6:34 am
I am talking about the the small bits like the ph0 and the ph1 and so on and the other end to fit into the 1/4 into the tool like that dewalt I told you that i have. That is why I was looking for a Micro Bit to 1/4" Drive Insert Bit Adapter. Do they make micro screw bits like PH0 AND PH1 AND SO ON that is a 1/4 drive the part that fix into the tool.
That is why I show you the photo of bits that I have the part that go into the tool is small 4mm and that won't fix into the tool.....
I hope you now understand what I am trying to tell you the base of the screw bits are small that is why I was looking for a 1/4 adapter like the one I told you I older From wiha. you can see it on the link in my last post... https://www.wihatools.com/tech-tools/mi ... it-adapter I am not talking about the size of the screw bits I am talking about the other end of the bit that go into the tool itself 4mm to a 1/4 bit adapter.
 Post Posted: Thu Nov 02, 2017 10:58 pm
I recommend the Wiha bit sets. I haven't recently tested anything else. Let me know what you end up choosing and why. Scott.
 Post Posted: Fri Nov 03, 2017 8:30 pm
What wiha bit set do you using on laptops.?
 Post Posted: Fri Nov 03, 2017 10:47 pm
I use this one: https://www.wihatools.com/bits/bit-sets ... bit-holder
This also allows me to disassemble hard drives for destructive purposes (as well as to get the magnets), power supplies and other devices assembled with security screws. Let me know what you choose and why. Scott.
 Post Posted: Tue Nov 07, 2017 3:36 pm
Ok so this is for the laptops right. does this comes with a 1/4 adapter....
Why do you like this set?
I got the bit the one I order and it works great with the bits i have.
 Post Posted: Tue Nov 07, 2017 8:03 pm
You'll know if you click on the link I posted. ;)
Scott wrote:
...This also allows me to disassemble hard drives for destructive purposes (as well as to get the magnets), power supplies and other devices assembled with security screws...
 Post Posted: Mon Nov 13, 2017 7:52 am
Why do they look like they can fit dry wall screws.????????
I watch the video again about upgrading and repairing laptops computers.
what is the differences between micro and precision and minuter screw bits...
thanks.
 Post Posted: Mon Nov 13, 2017 3:30 pm
A given bit can drive any type of screw with a matching head: https://en.wikipedia.org/wiki/List_of_screw_drives
You'll find definitions for those (and many other) terms in the dictionary. See the following example: Precision
 Post Posted: Tue Nov 21, 2017 6:00 pm
I am going to stay with the jewelry screwdriver bits kit that will fix into my adapter that I order from wiha and it fix into my 1/4 dewalt screwdriver. and leave the other bigger stander drywall bits for desktop computers.
thanks.
 Post Posted: Tue Nov 21, 2017 7:30 pm
Sounds like a good idea. Scott.
