Author |
spiderman
Post subject: electric screwdriver for laptop Posted: Thu Oct 19, 2017 7:38 pm |
Post subject: Re: electric screwdriver for laptop Posted: Thu Oct 19, 2017 11:08 pm |
Site Admin |
I don't know anything about that one. I'd want to see a link to the mfr. page including specifications, price and other detailed information, or possibly a written review (I normally won't spend time watching videos). From a quick glance it appears to be corded and for the last 30 years or so I've only used cordless models, so that is what I would recommend: https://www.amazon.com/Best-Sellers-Ind ... ial/552750
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Tue Oct 24, 2017 7:13 pm |
Quote: Ok so I would need a bit holder for my dewalt screwdriver for small laptop screws so what would i need I guess maybe a bit hold for 1/4 that part that goes into the screwdriver and the other end would be to hold the bits of like ph1 and maybe more that size.... this is the dewalt screwdriver i have https://www.amazon.com/DEWALT-DW920K-2- ... HV3C11X83E so what bit holder would i need to hold small bits for this screwdriver screw bits of ph000 ph00 ph0 ph1 and maybe more????/????/ I went to the local stores and I can't find any bit holder with a 1/4 shaft and the other end small enough to hold those type of bits scott????
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Wed Oct 25, 2017 5:23 am |
Post subject: Re: electric screwdriver for laptop Posted: Wed Oct 25, 2017 10:58 pm |
Site Admin |
spiderman wrote: I went to the local stores and I can't find any bit holder with a 1/4 shaft and the other end small enough to hold those type of bits scott???? I recommend Wiha bit sets: https://www.wihatools.com/bits/bit-sets
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Thu Oct 26, 2017 12:19 am |
Post subject: Re: electric screwdriver for laptop Posted: Thu Oct 26, 2017 11:53 am |
Site Admin |
spiderman wrote: I just looking for a 1/4 adapter to hold these bits to remove screws from the laptops with my dewalt screwdriver... They are very common and should be available at any hardware store. Here are some online: https://www.amazon.com/Best-Sellers-Hom ... 8107039011
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Sat Oct 28, 2017 2:24 am |
Scott wrote: spiderman wrote: I just looking for a 1/4 adapter to hold these bits to remove screws from the laptops with my dewalt screwdriver... They are very common and should be available at any hardware store. Here are some online: https://www.amazon.com/Best-Sellers-Hom ... 8107039011You are not understanding me a 1/4 hold on the bit holder will not work with these bits. I am looking for a bit holder that has a about a 4mm hole and a shank 1/4 to fix the dewalt screwdriver. I don't know if these one of these bit holder will fix these screw bits.... the shaft of these bits are not 1/4 so they will not fix into the dewalt screwdriver https://www.google.com/search?q=4mm+bit ... 00&bih=769I hate to buy something online and it don't work... and I can't find them in any hardware store. I try home depot I try ace hardware and I also try lowes and menards. if you go to to this link go here and you know what I am talking about the bits are smaller then 1/4 I have this kit but the screwdriver is to slow https://www.walmart.com/ip/Hyper-Tough- ... t/45715100 then click on here https://www.google.com/search?q=4mm+bit ... 00&bih=769Then let me know what you think I should do. see below how small the end are they won't fix in a 1/4 bit adapter or in the dewalt screwdriver. so what adapter would i need to get so I can use these bits in the dewalt screwdriver.
Attachments: |
Post subject: Re: electric screwdriver for laptop Posted: Sat Oct 28, 2017 8:17 am |
Site Admin |
If your screwdriver won't accept standard bits or bit holders then I recommend you get one that does. See my previous posts above for recommendations. Scott.
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Sat Oct 28, 2017 6:02 pm |
Scott wrote: If your screwdriver won't accept standard bits or bit holders then I recommend you get one that does. See my previous posts above for recommendations. Scott. What do you think of this kit https://www.ifixit.com/Store/Tools/64-B ... F145-299-1it has a 1/4 to 4mm adapter in this kit. I hate to buy another kit just to have this adapter so I can use it on my dewalt screwdriver.
Post subject: Re: electric screwdriver for laptop Posted: Sat Oct 28, 2017 11:37 pm |
Site Admin |
spiderman wrote: What do you think of this kit... I can't vouch for anything I haven't tested myself. Let me know what you think if you get it. Scott.
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Tue Oct 31, 2017 10:07 am |
Quote: which kit do you have? for laptops....... ?????????????????????????????????????????????????????????????????????????????????
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Tue Oct 31, 2017 11:26 am |
Post subject: Re: electric screwdriver for laptop Posted: Tue Oct 31, 2017 9:38 pm |
Site Admin |
I don't have any experience with non-standard drivers and bit sets so I don't know what would work with the bits you have now. Best to start over with more standard tools. I personally use several older Black & Decker drivers and drill/drivers with a number of different bit sets that I've accumulated over the years. Scott.
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Wed Nov 01, 2017 3:18 pm |
Scott wrote: I don't have any experience with non-standard drivers and bit sets so I don't know what would work with the bits you have now. Best to start over with more standard tools. I personally use several older Black & Decker drivers and drill/drivers with a number of different bit sets that I've accumulated over the years. Scott. I got it you saying that small laptop screws are as the same size as desktop screws am i right. What size screw-bit did you used on the upgrading and repairing laptop 2nd edition in the video when taking out the keyboard hard drive and the cd-rom drive....... What is your version on standard tools. I order that bit to give this company a chance. and see how things go. weeeeeeeeeeeehaaaaaaaaaaaaaaaaaaaaaa
Post subject: Re: electric screwdriver for laptop Posted: Wed Nov 01, 2017 11:52 pm |
Site Admin |
spiderman wrote: I got it you saying that small laptop screws are as the same size as desktop screws am i right. The screws used in laptops are generally much smaller than those used in desktops. Quote: What size screw-bit did you used on the upgrading and repairing laptop 2nd edition in the video when taking out the keyboard hard drive and the cd-rom drive... I believe I used PH0 or PH1 bits, probably from Wiha. I thought you were talking about the end of the bit that fits into the tool vs. the end that fits into the screw. In that case using standard bits means they fit in the standard tools. The screw heads vary among laptops so you need to use the correct sized bit to fit the screw you are trying to remove. Scott.
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Thu Nov 02, 2017 6:34 am |
Quote: I believe I used PH0 or PH1 bits, probably from Wiha. I thought you were talking about the end of the bit that fits into the tool vs. the end that fits into the screw I am talking about the the small bits like the ph0 and the ph1 and so on and the other end to fit into the 1/4 into the tool like that dewalt I told you that i have. That is why I was looking for a Micro Bit to 1/4" Drive Insert Bit Adapter. Do they make micro screw bits like PH0 AND PH1 AND SO ON that is a 1/4 drive the part that fix into the tool. That is why I show you the photo of bits that I have the part that go into the tool is small 4mm and that won't fix into the tool..... I hope you now understand what I am trying to tell you the base of the screw bits are small that is why I was looking for a 1/4 adapter like the one I told you I older From wiha. you can see it on the link in my last post... https://www.wihatools.com/tech-tools/mi ... it-adapter I am not talking about the size of the screw bits I am talking about the other end of the bit that go into the tool itself 4mm to a 1/4 bit adapter.
Post subject: Re: electric screwdriver for laptop Posted: Thu Nov 02, 2017 10:58 pm |
Site Admin |
I recommend the Wiha bit sets. I haven't recently tested anything else. Let me know what you end up choosing and why. Scott.
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Fri Nov 03, 2017 8:30 pm |
Scott wrote: I recommend the Wiha bit sets. I haven't recently tested anything else. Let me know what you end up choosing and why. Scott. What wiha bit set do you using on laptops.?
Post subject: Re: electric screwdriver for laptop Posted: Fri Nov 03, 2017 10:47 pm |
Site Admin |
I use this one: https://www.wihatools.com/bits/bit-sets ... bit-holderThis also allows me to disassemble hard drives for destructive purposes (as well as to get the magnets), power supplies and other devices assembled with security screws. Let me know what you choose and why. Scott.
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Tue Nov 07, 2017 3:36 pm |
Scott wrote: I use this one: https://www.wihatools.com/bits/bit-sets ... bit-holderThis also allows me to disassemble hard drives for destructive purposes (as well as to get the magnets), power supplies and other devices assembled with security screws. Let me know what you choose and why. Scott. Ok so this is for the laptops right. does this comes with a 1/4 adapter.... Why do you like this set? I got the bit the one I order and it works great with the bits i have.
Post subject: Re: electric screwdriver for laptop Posted: Tue Nov 07, 2017 8:03 pm |
Site Admin |
spiderman wrote: Ok so this is for the laptops right. does this comes with a 1/4 adapter... You'll know if you click on the link I posted.  spiderman wrote: Why do you like this set? Scott wrote: ...This also allows me to disassemble hard drives for destructive purposes (as well as to get the magnets), power supplies and other devices assembled with security screws...
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Mon Nov 13, 2017 7:52 am |
Scott wrote: spiderman wrote: Ok so this is for the laptops right. does this comes with a 1/4 adapter... You'll know if you click on the link I posted.  spiderman wrote: Why do you like this set? Scott wrote: ...This also allows me to disassemble hard drives for destructive purposes (as well as to get the magnets), power supplies and other devices assembled with security screws... Why do they look like they can fit dry wall screws.???????? I watch the video again about upgrading and repairing laptops computers. what is the differences between micro and precision and minuter screw bits... thanks.
Post subject: Re: electric screwdriver for laptop Posted: Mon Nov 13, 2017 3:30 pm |
Site Admin |
spiderman wrote: Why do they look like they can fit dry wall screws.? A given bit can drive any type of screw with a matching head: https://en.wikipedia.org/wiki/List_of_screw_drivesQuote: what is the differences between micro and precision and minuter screw bits. You'll find definitions for those (and many other) terms in the dictionary. See the following example: Precision
spiderman
Post subject: Re: electric screwdriver for laptop Posted: Tue Nov 21, 2017 6:00 pm |
Scott wrote: spiderman wrote: Why do they look like they can fit dry wall screws.? A given bit can drive any type of screw with a matching head: https://en.wikipedia.org/wiki/List_of_screw_drivesQuote: what is the differences between micro and precision and minuter screw bits. You'll find definitions for those (and many other) terms in the dictionary. See the following example: PrecisionI am going to stay with the jewelry screwdriver bits kit that will fix into my adapter that I order from wiha and it fix into my 1/4 dewalt screwdriver. and leave the other bigger stander drywall bits for desktop computers. thanks.
Post subject: Re: electric screwdriver for laptop Posted: Tue Nov 21, 2017 7:30 pm |
Site Admin |
Sounds like a good idea. Scott.
