Scott Mueller's Upgrading and Repairing PCs Forum • View topic - Certain POST audio error code for HP mp8200 PC
 Post subject: Certain POST audio error code for HP mp8200 PC
 Post Posted: Fri Nov 10, 2017 6:19 pm
Scott, I've been trying to install a SSD in the PC that my parents usually use. However, not only is the screen blank, but I generally hear five long beeps, then a pause, then five long beeps again. The same basic situation occurred even after I took out the memory modules and even after I put the PC's traditional HDD back in. Sadly, I don't know what kind of BIOS the PC uses. Scott, could you or some other member of this forum help me out here? Is helpful?
 Post subject: Re: Certain POST audio error code for HP mp8200 PC
 Post Posted: Fri Nov 10, 2017 11:08 pm
You need to find out the manufacture or model number of the motherboard to find out the beep codes. I also googled and someone on a HP support forum said it's either a motherboard problem or a ram. Try removing one module at a time and restarting. Maybe reseating the ram would help. I'm just guessing by what I've read from google searches though.
 Post Posted: Fri Nov 10, 2017 11:23 pm
I did find a replacement motherboard for it....
http://cybersgeek.com/HP-611835-001-Int ... otherboard
 Post Posted: Fri Nov 10, 2017 11:25 pm
If you put the PC back to the original configuration it was in before the error occurred and yet the error still occurs then one or more of the original components has either failed or has not been properly reinstalled. I would first insure that everything is properly installed in the pre-error configuration and if that didn't help then I would begin removing and replacing components with known-good spares until the error no longer occurred. If you do that let me know what the problem turned out to be. Scott.
 Post Posted: Sat Nov 11, 2017 12:11 am
I have apparently solved the five-long-beeps problem by reseating the memory modules. (Remember ?). To be honest, I can't say that I didn't switch the modules. The traditional HDD is currently back in the system. According to instructions that came with the SSD drive, I'm apparently supposed to initially keep the old drive installed internally and attach the new drive externally with a dock or something. However, the traditional HDD has a Windows Vista Home Premium installation. I want to install Windows 7 Professional on my .
 Post Posted: Sat Nov 11, 2017 1:02 am
 Post Posted: Sat Nov 11, 2017 2:22 pm
