Post new topic Reply to topic  [ 220 posts ]  Go to page 1, 2  Next
 Post subject: New PC Build
 Post Posted: Thu Dec 29, 2016 7:57 pm
It's been Seven years since my last build,so I figured it was time for a new pc.
1)Power Supply,
I'm wondering what brands are recommended by you today Scott. I seem to remember you recommending PC Power & Cooling, but then they were bought by OCZ and then Firepower Technology. So I don't know if they still produce Scott Mueller recommended PSUs. What about Corsair or Silverstone?.
Ok here is a PC Power and Cooling Silencer. Looks good but not sure it will fit in the case I picked.
2) Ram Choice,
Great deal!
3) CPU Choice,
Found a moderately affordable CPU- Intel Core i5-7500 Kaby Lake Quad-Core 3.4 GHz LGA 1151 65W BX80677I57500 Desktop Processor
4) Motherboard Choice,
The Gigabyte GA-H270M-DS3H
I wasn't going to use built in video but I think I might now. Would really like to be able to connect two HDMI monitors though.
5) Case- Corsair Obsidian Series 350D CC-9011029-WW Black Aluminum / Steel MicroATX Case with Window. Looks great!
6) SSD Choice,
After watching your SSD video I think This would be a great option. I believe the motherboard I chose has the correct connector also.
 Post subject: Re: New PC Build
 Post Posted: Fri Dec 30, 2016 11:50 am
I do still recommend PC Power & Cooling and also recommend Corsair.
It will fit in any case that supports a standard ATX power supply.
After watching your SSD video I think This would be a better option. I believe the motherboard I chose has the correct connector also.
That motherboard does have an M.2 socket on the underside of the board and I do recommend using M.2 drives when possible, such as in this case. Scott.
 Post Posted: Fri Dec 30, 2016 2:23 pm
Right now I use dual monitors and one is connected via DVI and one through HDMI. Nothing wrong with this setup so I'm just gonna do the same thing and not waste money on a video card when I don't even play games at all.
 Post Posted: Fri Dec 30, 2016 2:31 pm
Purchased the Motherboard today from Amazon. Gonna purchase the items one by one, can't afford to get everything at once.
 Post Posted: Fri Dec 30, 2016 2:51 pm
Scott I read a few of the reviews on Amazon on the SSD that I picked. They mention you need a "retaining screw" and that it's not provided by Samsung. Is this something that should come with my motherboard?.
 Post Posted: Fri Dec 30, 2016 7:10 pm
I'd like this post to be deleted because I'm no longer using the case I mentioned. Since there is no option for me to delete it, I'm editing it.
 Post Posted: Sat Dec 31, 2016 1:30 am
That motherboard only has a single chassis fan connector, so I'd only connect the rear fan especially if you didn't have hard drives installed in the front of the chassis. Note that the 750W PSU is massive overkill on an ITX motherboard system like this, you could easily get away with a 150W supply although I don't know of any quality units rated that low. In any case, the 750W supply will work fine (it will essentially be idling) and the cooling will be the least of the concerns with actual power usage this low. I'd recommend a smaller case considering the motherboard and boot drive you are using. Scott.
 Post Posted: Sat Dec 31, 2016 12:59 pm
That link is incorrectly going to the wrong Motherboard. GA-H170M-D3H is the correct model number. I'll have to look for different case. I just really like removable motherboard tray. Anyway I also edited the link in the first post so it would go to the correct MB.
 Post Posted: Sat Dec 31, 2016 1:17 pm
Delete this post please and thank you!.
 Post Posted: Sat Dec 31, 2016 1:30 pm
Delete this please.
 Post Posted: Sat Dec 31, 2016 1:38 pm
So really all that will be in the case is the Motherboard with components.....I may get a HDD to put it in there for back up, but not even sure if that's worth it, since I could get one of those docking stations like you have in your video and do it that way. I'm sure it would make for a faster backup if I put the HDD in the case though. Yes the Power Supply is overkill...
 Post Posted: Sat Dec 31, 2016 2:02 pm
Ok Scott, what do you think about Corsair RMi Series RM650i 650W 80 PLUS GOLD Haswell Ready Full Modular ATX12V & EPS12V SLI and Crossfire Ready Power Supply with C-Link Monitoring and Control?. Instead of the Pc Power & Cooling 750 watt?. It's got a 10 year warranty compared to 7 on the Pc Power & Cooling, and if I wanted to I could get the same exact model except the 750 watt version for $4.80 more. Sure maybe 750 watts is overkill, but for the price difference, why not?.
 Post Posted: Sat Dec 31, 2016 5:21 pm
The critical reviews of the CORSAIR RMi Series RM750i on Amazon are a little bit scary. Strange because all the reviews on Newegg are great.
 Post Posted: Sun Jan 01, 2017 12:36 pm
I was going to use Win 7 Pro 64 bit again, but since support is ending soon I may just go with Win 10 Pro 64 bit. Not necessarily what I want to do but I'd rather have an OS that it still supported for a few years while I use it, especially for a brand new build.
 Post Posted: Sun Jan 01, 2017 6:09 pm
FatGuy wrote:
Corsair Carbide Series CC-9011070-WW. Looks ok, I could leave one of the 120 mm fans in the front, remove the other one from the top and then purchase two 80mm ones for the back.
If you use that case I would leave the fans as-is, it looks like they put some design effort into the cooling.
The motherboard normally includes that screw.
Those reviews are a little scary. I'd probably consider something else.
Note that Win7 is supported until Jan. 14th 2020.
 Post Posted: Sun Jan 01, 2017 8:30 pm
I'll keep looking at power supply units. As for keeping the fans as they have them there are 2 included in the front(120mm) and 1 for the Top(120mm) included. So that doesn't equal more air flow out than in. I'm just stuck on that because that's what I've always remembered you teaching. I'll defer to you on the cooling though. So with that info, does it still sound like I should keep the fans as is?.
Cooling System
80mm Fans
Rear: 2 x 80mm
120mm Fans
Front: 2 x 120mm (2 included)
Top: 2 x 120mm (1 included)
Rear: 2 x 80mm
Bottom: 2 x 120mm
Side: 1 x 120mm
 Post Posted: Sun Jan 01, 2017 8:42 pm
For Windows 7 Scott, I don't understand this part on Gigabyte Website for the board,
1)Support for Windows 10/8.1 64-bit
2)Support for Windows 7 32-bit/64-bit
* Please download the "Windows USB Installation Tool" from GIGABYTE's website and install it before installing Windows 7.
How can I install software before installing an operating system?. Or this is just saying to install something so I can install Windows 7 from a Usb Flash drive and "install" the software from Gigabyte onto the drive so Windows 7 can be installed from a Usb Flash drive?. Very confused about what they actually are trying to say.
 Post Posted: Sun Jan 01, 2017 8:52 pm
Scott What do you think of Enermax?. ENERMAX REVOLUTION X’t II ERX750AWT 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Semi-Modular Active PFC Power Supply
Only a 3 year warranty though. Those reviews on Amazon are scary about the Corsair but I don't know how much I trust them anyway. I've read about some of them being fake and people actually getting paid to write fake reviews for the competition. Read that in an old Pc mag.com article.
I have to say though, it looks like Enermax has a really good reputation. A lot of good reviews on all their power supply units on Newegg. Glanced over some of the other Enermax reviews of other Power Supply Units on Amazon and couldn't find anything lower than 3 out of 5 stars. Just searched for "Enermax Power Supply" and scrolled through a few pages looking at the star ratings.
 Post Posted: Sun Jan 01, 2017 9:07 pm
On that note about Windows 7, what is the difference between,
Windows 7 Professional SP1 64-bit - OEM
And this,
Microsoft FQC-08289 Windows 7 Professional With Service Pack 1 64-bit - License and Media - 1 PC - 1 pack of Microsoft Windows 7 PRO SP1 64 Bit on DVD for OEM computers ONLY.
 Post Posted: Sun Jan 01, 2017 9:33 pm
That second link was from a 3rd party that sells on Newegg and they don't have very good reviews, so I guess I should forget about that one. I've been going back and fourth between Amazon on Newegg. On Amazon a lot of the reviews are saying they got some fake or pirated versions of Windows in the reviews. I'd think I'd be safe if I purchased from "Ships and Sold by Amazon.com". It's the 3rd party sellers I believe that you have to worry about. One kind of funny thing is one of the guys wrote a review of the OEM version of Win 7 Pro and proceeded to tell everyone that OEM versions are already installed on HP, Dell and other machines and that Amazon shouldn't be selling them because they are useless. I mean, come on, do some kind of research before you post.
 Post Posted: Sun Jan 01, 2017 9:35 pm
It wasn't a review it was the question and answer section,
ALL "OEM" branded software has already been installed and activated on a pre-loaded "branded" (Dell, HP, etc) computer. OEM software is NOT intended for resale under any circumstances, and in the case of Windows OS software, will most likely NOT activate successfully... meaning BIG WASTE OF MONEY TO BUY!!
Do NOT be fooled by the fact that it installs and all. Activation is the ultimate goal upon installation to determine if it is good or not! see less
By Bert Smith on August 27, 2014
 Post Posted: Sun Jan 01, 2017 10:50 pm
While it is more normal to have a depressurized case, it is also possible to have effective cooling with a pressurized case. Since that is how this one was designed, I'd probably leave it that way.
They are saying that you must use a tool (installed on another computer) to create a bootable Win7 install flash drive in order to install Win7 on a system with this board. I recommend using Rufus over the "Windows USB Installation Tool".
I can't really vouch for that one, if you get it let me know what you think. Of the PSUs you've mentioned so far I prefer the PC Power & Cooling.
If the descriptions are legitimate then the only differences between them are the price and the supplier, the actual media/licenses are identical.
 Post Posted: Sun Jan 01, 2017 11:35 pm
Hmmm. I'm gonna write to them and clarification about the Windows Usb utility thing.
 Post Posted: Sun Jan 01, 2017 11:49 pm
I downloaded the utility just to check it out and it seems it's just a utility to create a bootable Windows 7 image and so you can add USB 3.0 Drivers to the image and also "NVMe" drivers-which I'm guessing are drivers for SSD drive?. Only based on looking around the folder with Windows USB installation tool and finding folders in the "StorageControllers" folder, one "Intel_NVMe" and the other, "Samsung_NVMe".
The application has a Window with a drop down box that says "Source Path(CD-ROM) and another one below it that says "Destination Path(USB Drive)". Underneath three check boxes, "Add USB drivers to an offline Windows 7 image.", "Add NVMe drivers to an offline Windows 7 image.", and "Add Packages to an offline Windows 7 image."(This last one is ghosted out.
So to guess again I think that I could still use an external dvd writer to install connected to the USB 3.0 port on the front of the case. It'd probably be a little faster just using a USB flash drive image though. Correct?. I'm gonna get an external DVD writer anyway though just so I'll have it for certain things if I ever need it.
 Post Posted: Mon Jan 02, 2017 12:07 am
You can vouch for the PC Power & Cooling one, I think I'm gonna stick with that choice for now then. I may look at different cases though in the mean time. Next thing I purchase will be the CPU in about a week.
 Post Posted: Mon Jan 02, 2017 12:21 am
Here is a different case that looks better in my opinion to the other one. With this one I can at least have an Optical drive or two installed.
This case is great but I don't like the fact that it has top vents and there is no filter to put over these vents. I'd think a filter would be important, unless you want things falling into your case while you are working. Not sure how that would happen, but I see it as a reasonably possibility that you could accidentally knock something off your desk and it could fall into your case while the pc is up and running. That could be a problem.
 Post Posted: Mon Jan 02, 2017 12:49 am
Only thing I'm concerned with is on that case it says:
Maximum ATX PSU length 180mm
The dimensions for the PC Power & Cooling are 5.91" x 3.39" x 7.09"- If I'm correct, that last one is length, right?. Well according to google, 180mm is 7.08661, so rounded off I'd just make it.
 Post Posted: Mon Jan 02, 2017 1:10 pm
Yes, according to that it should fit fine. Scott.
 Post Posted: Mon Jan 02, 2017 1:28 pm
Scott, as far as optical drives, is there anything in particular you recommend? I was thinking about getting a Blu Ray burner, but I don't watch blue ray movies or anything. How would a blu ray burner be for making back ups or bootable diagnostic discs?. Worth the money?. Or should I just go with a regular Dvd burner?. Sorry Scott, my last PC I built was in 2010 I believe, so I'm a bit out of practice and don't know much about the current technologies.
 Post Posted: Tue Jan 03, 2017 1:31 pm
Found This! for the problem I was talking about earlier!. I'll order it!. Apparently the case doesn't come with it.
 Post Posted: Tue Jan 03, 2017 2:06 pm
Ok So I'm definitely going to get the Corsair Obsidian Series 350D CC-9011029-WW Black Aluminum / Steel MicroATX Case with Window.
 Post Posted: Tue Jan 03, 2017 7:32 pm
So what do you think about this Scott?. Is a Blu-Ray burner worth the extra money if I only use it for making bootable diagnostic cds, back ups, and possibly installing some software on occasion if for some reason I want to have a physical copy for some reason.
 Post Posted: Tue Jan 03, 2017 9:44 pm
No, unless you need to copy Blu-Ray movies or need to store that much data on an optical disc I'd recommend a DVD drive. DVD drives are all that is necessary to make bootable installation media. Normally I would recommend flash storage for any data you wanted to keep. Scott.
 Post Posted: Tue Jan 03, 2017 10:28 pm
Scott wrote:
No, unless you need to copy Blu-Ray movies or need to store that much data on an optical disc I'd recommend a DVD drive. Scott.
Thanks for all your help Scott!. I'll just get a regular OEM dvd burner.
 Post Posted: Fri Jan 06, 2017 12:54 pm
Scott, I see Intel Core i5-7500 Kaby Lake Quad-Core 3.4 GHz LGA 1151 65W BX80677I57500 Desktop Processor on sale at Newegg. It's only about $5 more than the other one I was going to choose. Is it worth it to purchase this one instead?
 Post Posted: Fri Jan 06, 2017 1:11 pm
Called Gigabyte to make sure that that version of CPU was supported and it is with the latest bios. So I think I'll get that one instead..
 Post Posted: Fri Jan 06, 2017 1:45 pm
Ok so far I've got the Motherboard coming tomorrow and just purchased the CPU and the Case.
 Post Posted: Fri Jan 06, 2017 1:51 pm
Around $633 more to spend on this machine. So much for being budget conscious and using integrated video.
 Post Posted: Fri Jan 06, 2017 2:16 pm
For that small difference in price I'd say it would be more than worth it. Scott.
 Post Posted: Fri Jan 06, 2017 7:18 pm
Question for you Scott. The motherboard only supports that CPU with the most current bios update. So F21 released on 12/12/2016. Now if the board I receive doesn't have that version of the bios, would it function enough for me to be able to use the Q-flash utility and flash the bios before I install the OS?. Or would I have to return the motherboard and make sure I got a new version with that bios version?. I'd have to guess that it would be fine and at least functional enough to do the flash.
Maybe this is a silly question because this type of situation must happen all the time. The new bios updates for newer versions of CPU's only upgrade certain features and maybe speeds, but they should still be functional enough to be able do flash. Is this correct Scott?. Or am I way off?.
 Post Posted: Fri Jan 06, 2017 7:30 pm
When I called Gigabyte support the guy had a really strong Chinese accent. So I believe he was saying that that cpu is supported with the newest bios. He was also saying that only certain boards with certain serial numbers have that bios installed. That shouldn't matter though I wouldn't think. I'd think you'd be able to flash update to the newest bios with that CPU even if the board doesn't "officially" support it without that version of the bios....
 Post Posted: Sun Jan 08, 2017 2:54 pm
I wouldn't bet on being able to do the update with the new (unsupported) CPU installed unless they specifically tell you that will work. I've had situations in the past where a motherboard would fail POST with an unsupported CPU, meaning it is dead in the water. In that case I had to install an older (supported) CPU in order to perform the BIOS update, then re-install the newer (now supported) CPU. Let me know what you find, Scott.
 Post Posted: Sun Jan 08, 2017 3:35 pm
I just call support back and ask for clarification so I can possibly ship the MB back for a newer version.
 Post Posted: Sun Jan 08, 2017 4:09 pm
Wouldn't I still be able to get into cmos without it passing the POST?. There was a certain number or range of numbers the guy told me for the serial number. After a certain number and higher, has the newest bios that I need. Below that doesn't. Stupid me didn't write those numbers down. I'll call back tomorrow. So say if it doesn't support it, I suppose I could ship it Gigabyte and have them flash it for me or send me a newer version of the board. I purchased it from Amazon. I could return and maybe ask them if they have a "newer batch" or something but I doubt they will understand what I'm talking about.
I just received the motherboard on Saturday but haven't opened the box that it shipped in. I kind of don't want to open the inner box or break the seal if I have to ship it back though. Maybe the serial number will be on the outer box.
 Post Posted: Sun Jan 08, 2017 4:52 pm
I can't seem to find a bios revision listed on the box. The serial number is listed though. So I opened the box and looked at the motherboard in the anti-static bag. Can't find a bios revision listed on it. They should put this on a stick on the box, that would be helpful. I did notice there is a hole in the anti-static bag though. Maybe I should just return it to Amazon for now?. It's return eligible till Feb 6th.
What do you think Scott?. The little hole in the anti-static bag does make me nervous and there wasn't even a piece of tape or anything on the motherboard box. I could always return it, and get my money back and wait to purchase the mother board for a month or so. At that point maybe I'll get the F21 bios version?.
 Post Posted: Sun Jan 08, 2017 5:36 pm
This H270 chipset version looks good. However, I can't seem to find it available anywhere yet. Is that chipset even released yet Scott?.
 Post Posted: Sun Jan 08, 2017 5:50 pm
I've only found it available for pre-order overseas. It was $114 as converted from 92.99 GBP on pre-order. Not sure how much overseas shipping is though. Do you think it's a good idea to order it from overseas as a pre-order?. Or I could just wait. It supports my CPU I ordered so that's good.
 Post Posted: Sun Jan 08, 2017 6:06 pm
Ok It's all boxed up and ready to go. Amazon returns are simple and they even pay for return shipping.
 Post Posted: Sun Jan 08, 2017 6:21 pm
Actually I put in my Basket and the price was cheaper. It ends up being $122 total in USD with shipping.
 Post Posted: Sun Jan 08, 2017 6:35 pm
With This board I will also be able to upgrade to an Intel Optane drive when they become available. Hopefully the board will be available soon.
 Post Posted: Sun Jan 08, 2017 6:37 pm
According to Intel The H270 chipset is already available. So that motherboard should be available soon.
 Post Posted: Sun Jan 08, 2017 10:43 pm
Intel's Optane.
 Post Posted: Mon Jan 09, 2017 4:29 pm
Called Gigabyte Support and they told me mid-February for a release date for that board. So I'm gonna wait and I'll purchase the other parts first.
 Post Posted: Mon Jan 09, 2017 6:11 pm
So I went on to purchase some RAM. I ordered one of THESE.
Kingston Value Ram
Those are in the Qualified Vendor List. So I'll get one more module before the build and possibly 2 more in the future to fully upgrade the ram in the GA-H270-DS3H.
 Post Posted: Mon Jan 09, 2017 8:00 pm
Scott, Question about SSD interface/form factor.
This one says the "interface" is "PCI-Express 3.0 x4" but the "form factor" is "M.2 2280". My understanding of an "interface" is just something that you plug into. "Form Factor" is a set of physical specifications.
Cheaper one. The "interface" is "SATA III" and the "form factor" is "M.2 2280" which is the same form factor as the expensive one.
Ok so is the only advantage of having the cheaper one connect to the M.2 2280 slot, is that it takes up less space or something and leaves some 2.5" bays free?. I'm just confused as to why they would connect to the same connector which they describe as the "form factor" but have a different "interface". Why have it connect to the M2 but actually go just as slow as connecting to just a regular Sata III port?. To me that doesn't make much sense. Now I'm thinking of getting the more expensive one because it connects to PCI express Generation 3 x4 bus, which is so much faster. Otherwise what is the point of purchasing an SSD that connects to M2 but runs at the same speed as connecting it to Sata III?.
Help me learn Scott. Maybe I'm mis-understanding things here because of the terminology used. It just sounds wrong.
 Post Posted: Tue Jan 10, 2017 12:29 am
Interfaces are different from form factors, however a form factor usually specifies one or more interfaces. There is no such thing as a "SATA III" interface, so the former appears to be a more accurate usage of the terminology, but they are different nonetheless.
The M.2 standard supports 3 different interfaces. The examples you posted use two different interfaces (PCIe vs. SATA). You would have to make sure that the motherboard supported both the form factor and the interface you choose. Let me know what you find, Scott.
 Post Posted: Tue Jan 10, 2017 1:15 pm
Yes I believe the GA-H270M-DS3H supports both the "form factor" M.2 and the PCI Express 3.0 generation and has one running at x4 -"Interface".
 Post Posted: Tue Jan 17, 2017 7:13 pm
Scott, for future reference any tips for when I install Windows 7 pro 64 bit on this new pc?. Specifically I'm worried about it installing Windows 10 without my permission.
 Post Posted: Tue Jan 17, 2017 7:16 pm
Or is worrying about it installing without my permission something I no longer have to worry about?.
 Post Posted: Tue Jan 17, 2017 7:22 pm
Since the "free upgrade" option has technically expired, that is no longer an issue. Scott.
 Post Posted: Fri Jan 20, 2017 3:25 pm
Purchased 2 more sticks of Ram today. So I'll be getting one more later and have the ram slots all full when I build. I'll be using the max amount of ram supported by the board, 64GB. Waiting on the SSD still because it isn't in stock for the cheapest price. Ok so now I have all the ram and will fill up the board to max.(1/25/17). Motherboard should be available soon. Still waiting on SSD to be in stock.
 Post Posted: Mon Jan 23, 2017 11:05 pm
Looking at This for a cpu heatsink/fan. I really don't like the flimsy plastic "screws" that come on the stock Intel coolers Scott. On my current one one of the screws is somewhat screwed up. I just want something more hearty.
 Post Posted: Mon Jan 23, 2017 11:40 pm
I'd spend that money on a better/faster CPU, but that's just me. <g> Scott.
 Post Posted: Wed Jan 25, 2017 11:40 am
Scott , when it says "Supports up to 70W Intel CPUs"...I don't understand because I thought that all cpu coolers will support any cpu as long they specify they fit the correct "form factor". For example, this one says it supports LGA 1151 / 1150 / 1155 / 1156. So does the wattage of the CPU even matter?. Or if it is one of those form factors, will they only be up to 70W anyway?.
 Post Posted: Wed Jan 25, 2017 3:21 pm
More information and video on the cpu cooler I will be purchasing.
 Post Posted: Wed Jan 25, 2017 3:23 pm
Intel makes CPUs of many different power (wattage) consumption levels in a given socket form factor. A given heat sink will be designed both for a specific level of power dissipation as well as a form factor, so you do have to consider both specifications.
 Post Posted: Wed Jan 25, 2017 4:11 pm
Scott, could you explain that in further detail for me or refer me to certain pages in your current U&R PCs?. So with the cpu I chose it is 65 watts. That is the amount of power it draws from the motherboard, yes?. Higher wattage CPUs would need more cooling because they product more heat, correct?. Having a 65 watt CPU and cpu cooler designed for "up to 70 watts", would that be considered "cutting it close"?. Or is it just, "It draws 65 watts" and that's it.
 Post Posted: Thu Jan 26, 2017 11:26 am
See the "Processor Cooling" section in the chapter on Processors.
Yes.
Correct.
If the processor draws up to 65W then it would be adequately cooled by a heat sink rated for 70W. However that does mean that when the CPU is under maximum load that the cooler will also be near maximum output. This generally means higher fan speeds with more noise, which can result in a shorter life for the fan as well as a greater ingestion of dust and dirt (more maintenance). I prefer to have an oversized cooler that only has to work at say half capacity for a given CPU. This results in a quieter, cleaner system that will last longer with less maintenance.
Note that the cooler you purchased is a special low-profile model, designed to fit in 1U (thin) rack servers. It offers no more cooling capacity than the one Intel supplies with the processor. If I wanted a better cooler for that money I would have purchased a much larger (taller, not artificially size-restricted) unit with a higher thermal design power rating. Scott.
 Post Posted: Thu Jan 26, 2017 2:15 pm
I have not purchased that cooler yet. I'll continue looking.
 Post Posted: Thu Jan 26, 2017 2:32 pm
What do think of the Cooler Master GeminII S524 Ver 2 - CPU Air Cooler with 120mm Silencio FP Fan and Accelerated Cooling System?. It's priced better also, but I can't find the power rating.
 Post Posted: Thu Jan 26, 2017 3:41 pm
Ok I confirmed with Coolermaster support that that cooler supports LGA 1151 and the "TDP" is 150 W.
 Post Posted: Thu Jan 26, 2017 4:33 pm
If you want a better than stock cooler that is more like it! The fan would barely need to run cooling a 65W CPU. Scott.
 Post Posted: Thu Jan 26, 2017 4:44 pm
Thanks Scott!. I'll put that one in my wish list and purchase it later on.
 Post Posted: Fri Feb 17, 2017 2:01 pm
Purchased motherboard. Today. So far I have the,
Motherboard
All Ram
Case
CPU
SSD
OS
PSU
Need to purchase
Optical Drive
CPU Cooler
 Post Posted: Fri Feb 17, 2017 3:11 pm
I'm looking at a different cooler now also. This one.Not sure about though as it might be overkill because I don't plan on overclocking and I don't play games. Might stick with the former choice, not sure though.
 Post Posted: Wed Mar 22, 2017 2:59 pm
Motherboard
All Ram
Case
CPU
SSD
OS
PSU
Need to purchase
Optical Drive
CPU Cooler
So I'm almost ready to build. I'll get the CPU cooler next and start the build finally. Not even sure I would really need an optical drive. They are so cheap though so I will get one.
 Post Posted: Sat Mar 25, 2017 12:10 pm
I received my PSU today. The box was half open like the tape had come off and the flaps were halfway up. Those packing plastic bubble like things were popped. The inner box that the actual PSU was in looks fine though, no dents in the box and the cellophane wrapping isn't even scratched. I don't know if this is something I should return it for as I don't know if the PSU was damaged during shipment. As far as I can tell though I don't think it was, because like I say the actual box with the PSU in it looks fine. It is a PC Power and Cooling Supply and it looks like they are really good about the way they package their PSUs for retail and/or shipment.
 Post Posted: Sat Mar 25, 2017 12:32 pm
From your description it sounds like it should be fine. Scott.
 Post Posted: Mon Mar 27, 2017 5:04 pm
Added everything up, $1195.58 minus the two parts I've got to order to complete my build. Cpu Cooler and Optical drive.
 Post Posted: Mon Apr 17, 2017 1:54 pm
Scott there is one thing I'm a bit confused on. The motherboard I've chosen supports Usb 3.1, the case on the other hand has two front "Usb 3.0" ports. Does the fact that these ports are Usb 3.0 mean then will only run at the Usb 3.0 speed even if I plugged them in the USB 3.1 headers on the motherboard?.
 Post Posted: Tue Apr 18, 2017 12:19 am
USB 3.1 Gen 1 has the same 5 Gb/s (aka SuperSpeed) maximum data signaling rate as USB 3.0 so most newer motherboards supporting USB 3.0 have simply renamed the ports as USB 3.1, even though there is no change in the performance or operation of the actual port. Scott.
 Post Posted: Fri Apr 21, 2017 2:55 pm
Building today. On the phone with coolermaster support. This cooler is a big 'ol pain in the ass to install. I started taking the green backing off even though I wasn't supposed to because it looked like it was supposed to be removed. Only a little bit. The guy on the phone said that was fine and it's just an anti-static barrier and I could just sort of put it back on and it's not a big deal.
 Post Posted: Fri Apr 21, 2017 3:33 pm
Finally got the stupid thing on. I had the plate that goes on the motherboard upside down. Plus I had to keep readjusting things to get everything in line. All the spring-loaded screws on the cooler had to be in just the perfect spot. Hope I didn't cause any damage or static damage. I didn't have my anti-static band on the whole time. I'm gonna believe it's fine. No visible scratches on the motherboard or anything. Just a huge pain in the ass Scott. Now I'll put the ram and SSD on the motherboard before I put it in the case.
 Post Posted: Fri Apr 21, 2017 4:03 pm
Cooler fan was in the way. I was able to get the retaining screw out though carefully and put the ssd in the m2 slot. Also was able to screw the retaining screw back in just snug enough. It only has to hold down the card so it doesn't have to be super tight. I'd like to be able to get some very short screwdriver though so I can get at it easier next time without having to take the cooler off. Scott you know where online I could get very very short screwdrivers. The screw is tiny also so I'll need a tiny philips head with a tiny amount of handle.
 Post Posted: Fri Apr 21, 2017 4:28 pm
Scott, question...This case has a rubber piece that I guess helps you line things up. Once everything is lined up there is one motherboard screw hole that doesn't have a standoff behind it. I'm guessing this is fine because there really is no other way to line up the motherboard correctly and having that standoff line up.
 Post Posted: Fri Apr 21, 2017 4:37 pm
I had one of the motherboard screws on my screwdriver head, magnitized it...Anyway I lifted the screwdriver and dropped it somewhere in the case. I shook the case and still can't find it. Hope it didn't get in the heatsink. I'll have to take the fan off the heat sink to check, but I don't think the fins are far enough apart that it could get stuck in there.
 Post Posted: Fri Apr 21, 2017 4:50 pm
Well there is no way it's in the case, because I shook it and turned it all different ways. It must have fell out on the floor or something.
 Post Posted: Fri Apr 21, 2017 5:00 pm
Cooler covers almost the entire motherboard. Crazy.
 Post Posted: Fri Apr 21, 2017 5:16 pm
Scott, PSU fan should be facing the bottom of the case when installed, is this correct?
 Post Posted: Fri Apr 21, 2017 5:45 pm
Ok Scott, I know you've answered this before countless times, but one more time. The case fans have 3 pin connections, but my motherboard has 4 pin fan headers...What to do?.
 Post Posted: Fri Apr 21, 2017 6:16 pm
Still a little concerned about that lost screw but honestly have no clue where it went. The space in between the fins on the heat sink is too small for the screw to fit. I took off the fan and looked and even put the same type of screw up to it to see if it would be able to. I turned the case upside down shook it side to side. Nothing. Now when I lost the screw the case was flat on it's side, so there is no way it could have gone under the motherboard if you consider how gravity works. There isn't much in the case for it be stuck on. Maybe it went on the floor somewhere and I'll find it tomorrow or something.
 Post Posted: Fri Apr 21, 2017 6:36 pm
I have a machine to blow up air mattresses that I use to clean out dust. I use that on it tomorrow, if it's in there somewhere that will make it fall out. I don't think it is though.
 Post Posted: Fri Apr 21, 2017 9:14 pm
Scott where can I find extremely short screwdrivers with a tiny phillips head?.
 Post Posted: Fri Apr 21, 2017 10:25 pm
https://www.wihatools.com/screwdrivers
I highly recommend them. Scott.
 Post Posted: Sat Apr 22, 2017 10:20 am
I'll be getting new case fans for this since the fans in the case both have only 3 pin connections. No point in running a case fan without PWM when the motherboard has that ability. Scott, don't most all motherboards purchased within the last 7 years or so have 4 pin headers anyway?. I don't understand why they would put 3 pin connections on the fans. If I had to guess I would say they are trying to save money and get the cheapest fans available.
This fan will replace the front fan.
This fan will replace the rear fan.
 Post Posted: Sat Apr 22, 2017 10:27 am
Although I'm thinking of just leaving the front fan-less. Only because a 140mm fan moves more air than a 120mm, so it will be moving more hot air into the case, while the 120mm struggles to keep up trying to remove the hot air. The 140mm would be in front of the drive cage to cool the drives, but there is nothing to keep cool.
With the cpu cooler fan there is only about 2-3 inches clearance between it and the rear fan.
 Post Posted: Sat Apr 22, 2017 11:30 am
I would only run a single rear fan. Scott.
 Post Posted: Sat Apr 22, 2017 1:54 pm
Alright then. What do you think about the fact that there is very little clearance between the rear fan and the actual CPU fan. Like I say about 2 inches. I would have to guess that whatever the cpu fan blows down, the rear fan would just be pulling out. I will get a picture for you.
 Post Posted: Sat Apr 22, 2017 4:19 pm
A few.
 Post Posted: Sat Apr 22, 2017 4:30 pm
See what I mean Scott?
 Post Posted: Sat Apr 22, 2017 5:17 pm
I also believe the front panel "notches" are broken. It still holds but is easily knocked over and open. There is a little panel that you are able to take off and that's what falls easily. I'm gonna see if I can just purchase a front panel replace instead of RMAing the entire case.
 Post Posted: Sat Apr 22, 2017 5:48 pm
The clearance seems fine. I would run both of the fans at lower speeds. Scott.
Ok I submitted a ticket with corsair so maybe I can get a replacement front panel for free.
 Post Posted: Sat Apr 22, 2017 5:49 pm
Ok then, should the PWM fans that I linked work fine then? You mean both a front 140mm and a rear 120mm?. Correct?.
 Post Posted: Sat Apr 22, 2017 7:35 pm
Hey Scott at least I didn't have a problem with the I/O shield this time!.
 Post Posted: Sat Apr 22, 2017 10:19 pm
By "both" of the fans I meant only the CPU and rear chassis fan. I don't see the need to run a front fan in this case. Scott.
 Post Posted: Sat Apr 22, 2017 10:25 pm
Ahh, Ok!. Thanks again Scott for all you help!.
 Post Posted: Sat Apr 22, 2017 10:39 pm
Scott, my PSU has two modes, "Normal Mode: Fan always operates with variable RPM determined by temperature and power loads."
Or,
"Silent Mode: Fan remains idle at specific temperature = Zero Noise. Reduce unnecessary rotation in order to increase the life span of the fan and dust accumulation. Decrease unnecessary consumption to increase the efficiency."
Silent mode makes the most sense to me, however I'd like you opinion on this.
 Post Posted: Sat Apr 22, 2017 10:55 pm
I would definitely choose silent mode to begin with. Scott.
 Post Posted: Tue Apr 25, 2017 2:15 pm
Scott, I forgot, when flashing the bios should I just flash the latest one?. They are cumulative correct?. Each successive update has all previous fixes and updates included. Yes?.
 Post Posted: Tue Apr 25, 2017 11:12 pm
Yes indeed. A BIOS flash image is a complete image of the ROM and when installed it completely replaces the previous copy. As such it is not cumulative in any way. Scott.
 Post Posted: Wed Apr 26, 2017 3:56 pm
Thanks Scott. I mis-understood the definition of the term "cumulative". Now I have a better understanding of it's meaning. Look at you Scott, teaching me vocabulary!.
 Post Posted: Wed Apr 26, 2017 3:58 pm
Corsair is replacing the front panel free of charge. They updated my "ticket" today and said it was approve so now I just have to wait for them to ship it out.
 Post Posted: Wed Apr 26, 2017 7:06 pm
That's good to hear! Let me know the outcome. Scott.
 Post Posted: Fri Apr 28, 2017 1:15 pm
Ok So I placed the order for the 120mm fan. I even purchased a Flash Voyager® Slider X1 USB 3.0 128GB USB Drive (Refurbished) from Corsair just to do my OS install, even though I could probably find one I could use. It was a great deal though at $21.99 and $4.89 shipping($26.88 total). So why not, right Scott?. My replacement front panel is scheduled for delivery next Thursday 5/4/17. So at that time I'll replace the front panel, add the fan and wire everything up. Then I'll download the latest bios and try and use Q-flash to flash to the latest Bios before making my image to install from the flash drive.
 Post Posted: Tue May 02, 2017 9:10 pm
Got the Usb drive today and made my image with the software from Gigabyte support. Had problems at first with it not adding the drivers. Tried a "Clean boot" and that didn't work, tried running the software in safe mode and that worked. Now just waiting on my case fan and front panel which should be here Thursday.
 Post Posted: Thu May 04, 2017 3:20 pm
Tried using the anti-vibration mounts for new case fan and it didn't go well. Took forever and was too much of a pain in the butt. Used the regular fan screws and it was a much better fit. There just wasn't much clearance the other way and I was trying to pull the rubber mounts out from the inside of the case and the heat sink got in the way. I replaced the front panel with the new one and attached the front panel connections to the motherboard. I'm gonna look everything over just to make I didn't miss anything and then start it up and try entering the bios and use Q-flash to flash to newest bios. Hopefully this goes well Scott!
 Post Posted: Thu May 04, 2017 6:04 pm
Well Scott, I'm having trouble getting the new pc to boot from the flash drive. It shows up in the bios setup and is also in the boot menu when hitting F12. I select it but get an error saying to insert a proper boot device. So it shows up in bios but for some reason I can't boot from it.
 Post Posted: Thu May 04, 2017 6:11 pm
I've contacted Gigabyte support on this but I'm not holding my breath. They still didn't get back to me from the last problem of their software not working correctly. I was able to fix that myself by using safe mode. However seems it still didn't work right because it won't boot from the "bootable" USB image I created.
 Post Posted: Thu May 04, 2017 6:26 pm
Try going in the BIOS Setup (with the device inserted) and change the boot order sequence so that the flash drive is first, then save and exit. Scott.
 Post Posted: Thu May 04, 2017 6:40 pm
Already tried that. I have my old pc to use for now while I wait for a response from gigabyte. I may just call them tomorrow. Apparently I'm not the only one with these problems.
 Post Posted: Sat May 06, 2017 5:41 pm
So I tried a different flash drive today. Tried different ports also. No luck. Hopefully Gigabyte gets back to be sometime next week.
 Post Posted: Tue May 09, 2017 4:15 pm
Got a reply from Gigabyte today saying that if the image was created successfully there should be two listings for my usb drive, one with the model number and one with "UEFI" in front. I replied and told them there was only one listing.
Also I read on the link that I put in my last reply that one guy tried extracting the tool to the root directory and that worked for some reason and got rid of the error. Although the error doesn't come up when run in safe mode, I'm thinking that it still didn't create the image correctly because the usb flash isn't bootable.
Gigabyte support also suggested I try running the tool from Windows 10 but I don't have any windows 10 pcs. I've tried loading optimized defaults in the cmos....Tried disabling everything else and just leaving my usb flash drive as the only boot device. Guess I'm gonna have to wait for Gigabyte to write back again. I think they need to re-write their usb installation tool software because it obviously has problems. They haven't updated it since November 2016.
 Post Posted: Tue May 09, 2017 4:18 pm
No there is only one listing with the model of the flash drive. There is not an additional listing with UEFI in the front. 5/8/2017 7:51 PM
Answer:
In that case the image is not created successfully otherwise there should be 2 listing from the Boot Menu.
Do you have a WIndows 10 image you can try booting off, you will see there will be 2 Boot option when you hit F12, your Windows 7 image should show the same if it's done correctly.
Thank you
 Post Posted: Tue May 09, 2017 4:19 pm
Question: I was able to use your usb installation tool to make a usb flash install for windows 7 pro 64 bit, using safe mode. That's the only way it would work. Now the problem is I'm unable to boot from it. I can select it in the boot menu if I press f12. However when I select it I get an error saying to insert a proper boot device and press any key. Please help! 5/4/2017 8:10 PM
Answer:
Hi Steve,
If the Image was able to be created successfully, during boot with the Boot menu it should register 2 listing with the flash drive.
One with the model # of the flash drive along with an additional listing with UEFI in front.
5/8/2017 7:12 PM
 Post Posted: Tue May 09, 2017 4:39 pm
I recommend Rufus for creating bootable Windows installation flash drives. Scott.
 Post Posted: Wed May 10, 2017 3:08 pm
Ok Scott. I actually got it to boot by using a different Usb Flash drive. It wouldn't boot as NTFS, but when I reformatted it as FAT32 it was bootable. Now the problem is I get and error and it can't find my Samsung SSD. I tried looking for the drivers online and then I burned them to a dvd and put the dvd in the pc at this type, browsed to the driver but still it couldn't find the SSD. The drivers were supposed to be integrated into the flash drive and in safe mode the tool "works" but I guess it just didn't add the drivers. So I don't know, maybe I'll just order a copy of Windows 10. I can't return this OEM version of Win 7 Pro 64 bit. Want to trade or something?.
 Post Posted: Wed May 10, 2017 3:58 pm
I can find the Nve driver from Samsung on their website but it's an application and and not a file.
 Post Posted: Wed May 10, 2017 4:21 pm
I called Samsung and they told me the only way to install windows 7 on the 960 EVO is to install windows 7 on a regular HDD and install the driver for the SSD, then clone the HDD to the SSD. I guess I could do that but it's a pain in the ass. So now every time I wanted to re-install I'd have to do the same thing or just make an image of Windows 7 installed with macrium reflect or some other imaging software. It'd be easier just to get Window 10 and then I wouldn't have to worry about this mess. Don't know what I'm gonna do at this point. Scott, do you have a need for a Windows 7 pro 64 bit license?.
 Post Posted: Wed May 10, 2017 4:27 pm
The issue is that the SATA host adapter is newer than the OS and thus unless set to legacy mode it won't be supported without a driver, which is not present on the Windows 7 install media. In that case you will need the Intel SATA preinstall driver added to the installation media to support AHCI mode during the install: http://www.gigabyte.us/Motherboard/GA-H ... support-dl
 Post Posted: Wed May 10, 2017 4:30 pm
It's attached to the m2 slot, not Sata.
 Post Posted: Wed May 10, 2017 4:51 pm
The M.2 slot is in fact a SATA 3 port. When an M.2 SATA SSD is installed the SATA 3 #0 port on the motherboard cannot be used as they share the same signals. See the motherboard manual for more information.
 Post Posted: Wed May 10, 2017 4:54 pm
Ok Scott, so should I be able to just burn that to a dvd and then browse for it when it asks for drivers?
 Post Posted: Wed May 10, 2017 5:07 pm
See the section in the manual titled "Installing the SATA RAID/AHCI Driver and Operating System". Scott.
 Post Posted: Wed May 10, 2017 6:28 pm
Ok Scott that didn't end up working. It gave me an error and said to contact my vendor for an updated driver. The first error I get to be specific before any of this is "A required CD/DVD device driver is missing". I also tried installing a different driver for the SSD that I found online. It showed up as Samsung Nvme. I clicked on it and it scanned for a bit and said "No new devices found". I'm really at my wits end with this thing. Seriously considering just getting a copy of Windows 10. I will have wasted the $125 I spent on Windows 7, but at least it will install without me having to jump through hoops. Gigabyte "support" has been worthless.
 Post Posted: Wed May 10, 2017 6:41 pm
Are you using a USB DVD drive? If not it won't be recognized at boot without the proper drivers being integrated into the installation media. I recommend installing from a USB DVD or Rufus created flash drive. Scott.
 Post Posted: Wed May 10, 2017 7:11 pm
I'm installing from a usb flash drive and I try and load the drivers from a dvd drive already installed on the pc. I also tried copying the driver files to a folder on the flash drive and that has not worked either. I think I might just install windows 7 on a regular HDD, then install the Samsung Nvme drivers and then clone the HDD to SSD. Then remove the HDD and get a usb 3.0 dock and make images for back up that way.
You see though the CD/DVD drive is recognized though Scott. That's where I'm installing the drivers from. That error I get about the CD/DVD driver has a different meaning than what it is saying, I think.
 Post Posted: Wed May 10, 2017 7:13 pm
Take a look at this video. This is the first error that I get,
https://www.youtube.com/watch?v=hiTV3hJAn5s
 Post Posted: Wed May 10, 2017 7:16 pm
He says that Windows 7 comes with an old driver called "EHCI" and you need "XHCI". That's what their useless software is supposed to do.
 Post Posted: Thu May 11, 2017 12:31 pm
Scott I was able to install Windows 7 using the dvd. I took out the windows 7 dvd when it asked for drivers and put in the dvd the I copied the driver I found for Nvme. Then when done loading the driver I just put the windows 7 dvd back in. The only problem is Intel Core i5-7500 Kaby Lake Quad-Core 3.4 GHz LGA 1151 65W BX80677I57500 Desktop Processor is not supported by Intel with Windows 7 so there is no driver for it. I also got a message I believe from Microsoft, saying that my hardware was designed for the latest version of windows so I will miss important security updates. Something like that anyway. So now Intel won't even support Windows 7. I could either purchase Windows 10 or get a graphics card. One of the reasons I chose this board and cpu combo was for the built in video. It would sure be a lot easier if I just purchased Windows 10. Anything I have to do that's important I leave to 3rd party software anyway. Surely I can change settings and things around in Windows 10 so it will be bearable.
 Post Posted: Thu May 11, 2017 1:06 pm
https://downloadcenter.intel.com/downlo ... ows-15-45-
That link says with 7th gen processors it only supports Windows 10.
 Post Posted: Thu May 11, 2017 1:13 pm
I hadn't changed the link in my first post yet and I was looking at the wrong graphics, thinking I had a 6th gen. So I looked in my device manager and was like, "oh duh!". So no support from intel and it's been such a pain in the ass installing. Microsoft got me!. I'm just gonna wait and purchase Windows 10 pro 64 bit. It should be a lot easier to install anyway.
 Post Posted: Fri May 12, 2017 6:04 pm
Ok Scott, I installed the beta version Intel HD 630 graphics driver from the motherboard website. However I also chatted with Intel support and they said they have no plans to release a driver for Windows 7 64 bit on 7th gen intel processors.
Also on that new pc "they" have blocked me from downloading updates because of my Kaby Lake Cpu,
https://support.microsoft.com/en-us/hel ... sion-that-
 Post Posted: Fri May 12, 2017 6:09 pm
I may try this Scott, but how long can I continue without dealing with more issues?. Especially now that it seems Intel is on board with screwing users of Windows 7. Given that I don't build new pcs very often though I think I might be better off getting Windows 10 pro 64 now. Sure it might be a pain tweaking it and getting it to the point where I like it but it'll be a much easier install with native support for Nvme. I'd also question how long it will be before Microsoft decides to screw the Windows 7 users again somehow.
 Post Posted: Fri May 19, 2017 8:09 pm
Ok I've got Windows 10 Pro 64 installed. Much much easier and smoother install. Windows boots very fast. I'm now wondering what these utilities do that are downloadable from the motherboard manufacturer. They really don't have much descriptions of them.
 Post Posted: Fri May 19, 2017 10:48 pm
Really enjoy the "Ultra-Fast Boot" option in the cmos and UEFI bios. Just figured out how to get into it after changing to "Ultra-Fast" boot. You have to hold shift down while clicking on restart.
 Post Posted: Fri May 19, 2017 10:54 pm
It's a great illusion.
 Post Posted: Sat May 20, 2017 9:51 am
Yeah, I thought I read that the pc isn't completely off when you use that option?. Not that that matters. I'd rather have it available right away instead of having to wait. New Pc seems to be working fine so far, which is surprising with how much I manhandled the motherboard putting that huge cooler on.
Well that can't be true because I turned the power off to the PC on the PSU switch for a while. Then powered it on and boot time was the same. It's a super fast boot.
 Post Posted: Sat May 20, 2017 12:05 pm
I did install Thunderbird for my mail on the new pc.
 Post Posted: Tue May 23, 2017 5:35 pm
Scott, I had a weird thing happen today. I got a notification from the realtek software saying that I removed and replaced an audio jack. I did not. I wasn't even listening to music or anything and haven't had any problems with audio. It just popped up and said that I removed an audio jack and then said I plugged in an audio jack.
 Post Posted: Tue May 23, 2017 6:22 pm
I guess this is a common problem with Windows 10 and Realtek audio...Some people have it worse then me. It's only happened once. Some say it's a driver issue and some say it's a front port issue. Now I can't hardly believe that it's a front port issue because that would me that every single person that has this issue has bad/broken front ports. That's laughable.
 Post Posted: Tue May 23, 2017 6:34 pm
Just for giggles I could always order a new front panel with the audio ports. The case is still under warranty but I doubt I will be able to prove the front panel is defective. Besides this has only happened once. Maybe I should wait to see if it ever happens again.
 Post Posted: Fri May 26, 2017 6:02 pm
It happened again today. More info on this problem. Apparently this has been an ongoing problem for years with realtek software.
 Post Posted: Sat May 27, 2017 3:39 pm
Scott, what do you think about this problem with the RealTek software saying I removed and replaced an audio cable?. I disabled the front panel audio. The problem is so common that even in the real tech software under "connector settings", there is a popup if I hover over "Disable front panel jack detection" that says "If front panel jack detection is not working properly, please check this option.". Well, I did and now there is no problem. However, I still consider this a problem because it's just a workaround.
 Post Posted: Sat May 27, 2017 4:44 pm
I took a picture of the front panel where the audio connects. I can not see any type of damage or anything so I doubt they would replace it for free. I still think it's a software problem.
 Post Posted: Sat May 27, 2017 4:47 pm
 Post Posted: Sat May 27, 2017 5:04 pm
Unfortunately some chassis do not include front panel connections that are properly designed to follow the Front Panel I/O Connectivity Design Guide and High Definition Audio Specification with regards to front panel jack detection. In that situation it is best to disable jack detection as you have done. Scott.
 Post Posted: Sat May 27, 2017 5:13 pm
I'm gonna place an order for the front panel piece just to see if maybe it does have some defect. If not than it's just a spare. Only $14.88 total with shipping, so it's not bad and I don't mind having spare parts for my case.
 Post Posted: Sat May 27, 2017 5:18 pm
The thing is that it doesn't do it all the time only after my pc has been on a while. I use the front panel usb slot to put in and take out a usb stick several times a day. I'm thinking maybe since it's a bit tight pulling the usb stick out that something or some wires connected to the audio jacks could be loose or something. I couldn't see anything wrong from looking at the part but I was not able to take it completely apart. Does this sound plausible?.
 Post Posted: Sat May 27, 2017 5:40 pm
It's possible but I suspect it's more likely a non-conforming design. You could see if the design matches the schematics shown in the documents I linked to in my previous post. Scott.
 Post Posted: Sat May 27, 2017 6:44 pm
Forgive my ignorance but what would I be matching up?. I can not find any schematics for the Corsair Obsidian 350D. Would I match up AC97 in the link and schematics for front panel audio of the case?.
 Post Posted: Sat May 27, 2017 6:55 pm
Wish I could recreate the issue, but like I say it's intermittent.
 Post Posted: Sat May 27, 2017 10:50 pm
You would disassemble the front panel connector assembly and trace the circuit to see if it matched the schematics supporting HD Audio as shown in the spec. documents I linked to. Note that AC97 is the old standard not supporting jack detection, HD Audio is the modern standard supporting jack detection. In other words if the front panel is wired like AC97 then jack detection is not supported. Scott.
 Post Posted: Sun May 28, 2017 1:31 pm
Well I tried "unticking" that button just to see if maybe unplugging and re-plugging the connector yesterday might have fixed things. It did it again, so I ticked the button again. I did order that front panel piece, so I could take this one out and dis-asemble it and trace the wires. Or I could just keep it as a "known good spare". Either that or I could replace it with the new one coming and untick the button just to see if it was maybe defective somehow. I think I should at least do that, then if I get the same problem I know it's the software or it's a non-conforming design like you said Scott. If it was a non-conforming design though wouldn't there be more reports of this same problem with this exact case?. I mean there are tons of reports of this same problem with realtek, going back to 2004.
 Post Posted: Thu Jun 01, 2017 3:29 pm
Something I just thought of....My old motherboard has the same RealTek audio and I didn't have this problem. Although I just let Windows handle things and didn't load the realtek software.
 Post Posted: Thu Jun 01, 2017 3:59 pm
After I replace the front panel, it's scheduled for Delivery on 6/6/17, I will re-enable the front panel detection to check if it was the front panel, which I doubt. If that works, fine. If not I'm gonna disable the built in audio and just get a PCI-E sound card instead. To be honest I would rather just get a sound card, since RealTek apparently has had this problem for many years.
 Post Posted: Thu Jun 01, 2017 5:18 pm
Ok Scott, today I used Ccleaner to disable RTHDVCPL from startup. Problem solved. I tried using headphones and plugging them in the front panel. Speakers muted and everything, unplugged it and speakers came back on. However I also tried plugging the headphones into the headphone port on the speakers and the sound was a bit lower than normal. Just had to adjust the volume on the headphone controls.
So to me, this proves it's not a driver problem but a problem with RealTek HD audio manager software.
Still gonna keep my order of my new front panel part and still gonna order a Sound Blaster sound card....Just because I know it's realteks problem that they obviously refuse to fix. There software doesn't work correctly and they don't care. Otherwise there wouldn't be so many reports of this exact problem.
 Post subject: Re: New PC Build
 Post Posted: Tue Jun 06, 2017 12:24 pm
Ok Scott, I received the new front panel today and just installed it. I re-enabled the Realtek Audio Manager and got the same "unplugged an audio device" and "plugged in an audio device". I knew it was the software, but figured I'd double check anyway. Look at it this way, now I have a "known good spare" for the front panel.
The sound card I'm looking at is $40 with free shipping. Seems like a good deal to me and maybe I can actually use the software that comes with it.
 Post Posted: Sun Jun 18, 2017 7:38 pm
Hey Scott. I just put in my new sound card and of course the sound is 10 times "better" than the built in sound. Also the software actually works with the hardware. No problems. Who would have thought...Next time I choose a motherboard I'm gonna have to find one that doesn't use realtek.
 Post Posted: Sun Jun 18, 2017 7:44 pm
That might be difficult as RealTek seems to be quite popular. However using a sound card is an excellent alternative. Thanks for letting me know the outcome. Scott.
 Post Posted: Sun Dec 03, 2017 1:50 pm
Just updating this as I've been running this PC for almost a year now problem free. I'm surprised I didn't cause any kind of static damage. When Gigabyte says "Ultra-Durable" they really mean it. I believe I had the board on an anti-static board on a mat. Just that I was really rough with the board getting that stupid big ass cooler on it. Next build I think I might just go with the stock cooler. The only problem I have with stock coolers is that they get a hell of a lot more dust embedded in them than aftermarket coolers for some reason.
Scott do you think anti-static worries are overemphasized?. Or are they not much of a problem as the used to be in years past?. I remember in years past seeing some motherboards and they just looked flimsy compared to today's offerings. I've also always been a little obsessed with anti-static precautions. I usually use a anti-static mat attached by alligator clip to an unpainted part of a case along with a wrist strap attached the same way. With this build I had pulled off the alligator clip on the wrist strap while fussing with the cpu cooler.
 Post Posted: Sun Dec 03, 2017 5:31 pm
Static is always a concern, but it depends a lot on the environment as to how much it could be an issue. I almost never wear a wrist strap however I always ground myself to a device before touching any components. Scott.
 Post Posted: Sun Dec 03, 2017 5:49 pm
So just periodically touching an unpainted surface should suffice correct?. Scott, something that I've only recently (within the last 6 years or so) noticed is when filling up at a gas station I see warnings on the pumps to ground or "Dis-charge" yourself before touching the pump. I never noticed this warning years ago, maybe early 90's or late 80's on the pumps. I've not heard of any accidents caused by this though but then again I have not googled it either.
 Post Posted: Sun Dec 03, 2017 6:26 pm
An unpainted GROUND point, yes. On a motherboard that would be the metal housing surrounding any of the back panel connectors or the metal pads around the screw holes.
...something that I've only recently (within the last 6 years or so) noticed is when filling up at a gas station I see warnings on the pumps to ground or "Dis-charge" yourself before touching the pump. I never noticed this warning years ago, maybe early 90's or late 80's on the pumps. I've not heard of any accidents caused by this though but then again I have not googled it either.
Gas pump static fires are definitely an issue. They are most commonly experienced by people who get back in to their vehicles while filling up, then return to the pump carrying a charge. Personally I never re-enter a vehicle during the refueling process, I either remain at the pump or busy myself cleaning the windows. Scott.
 Post subject: CPU upgrade?
 Post Posted: Wed Jan 24, 2018 6:19 pm
Scott I was thinking of upgrading the CPU on this. However, it seems the i7 is over $300. How long do you think before I can get it for $250-270?. Do you think I'd get much of a performance boost just going from the i5 7500(what I have now) to the i5 7600?. Would it even be worth it?
 Post Posted: Wed Jan 24, 2018 9:17 pm
I wouldn't recommend a CPU upgrade unless it was at least 50% faster in actual performance. Even so, most people won't notice an upgrade unless it is twice as fast (i.e. 100% faster). Scott.
 Post Posted: Sun Feb 04, 2018 1:36 pm
Think I might have mentioned this problem before. I have been having problems with disabling the COM1 and LPT ports on this board. I had set them both to disabled and they still showed up with the COM1 port saying it had a problem (Code 10) can't start device. So after restarting enabling them both and then restarting and disabling they would be fine. Or so I thought. I'd check the device manager again periodically and notice the "can't start" problem was back. So the last time this happened I just decided to leave them enabled. So now the COM1 port shows up but LPT is gone from the system. I'm not sure but I think I might have just uninstalled the LPT port from device manager in frustration.
Not that I need a LPT or parallel port, just would like to know where it went.
 Post Posted: Sun Feb 04, 2018 2:15 pm
So now I went back in and disabled them both. This is the cmos setup under Peripherals>Super IO Configuration. I disabled both the Serial Port and Parallel Port. Then I save and exit. Wait for windows to load. Wait a few minutes, check device manager and the ports don't show up as it should be. So I restarted and went back into the cmos setup and enabled them both again. Now everything is back to normal and the LPT port is also back. The defaults for both of these settings is enabled.
Honestly Scott, why would Gigabyte have Serial Port or Parallel Port headers on a modern motherboard?. I've sent an email to Gigabyte support about this last week but have not heard back yet. I'm hoping that maybe if I just leave them enabled I won't have any issues. Just wanted to disable them since I don't use them. Maybe this is some weird Window 10 issue and Windows 10 gets "confused" by Serial Ports and Parallel ports?. Scott, what do you think is going on with this?.
 Post Posted: Tue Feb 06, 2018 1:30 pm
Today I after I started up my machine I checked device manager. The LPT port is absent again.
 Post Posted: Tue Feb 06, 2018 1:56 pm
This looks like a similar "problem". Although I guess it's not really a "Problem" since I don't use the parallel port.
I think that may explain the parallel port/LPT port "problem". It doesn't address the strange COM port problem that I explained earlier though. For now I still have both ports enabled in the cmos setup. "Communications Port(Com 1)" is still showing in device manager under "Ports (COM & LPT)". However LPT1 or parallel port is missing.
 Post Posted: Tue Feb 06, 2018 1:59 pm
Actually if you look at page 2 of the link I posted you'll see this,
Hi All,
Same issue with COM ports and the new WIndows 10 update. We use serial printers for boarding passes and receipts. All are down. Uninstalling and allowing the system to redetect from Device Manager is a temporary fix, but as others have stated, once you reboot the system, they're broken again.
Note that this has nothing to do with printer drivers. I've even tested with the built in WIndows 10 Generic Text and ended up with the same results.
May have to script removal of the COM/LPT ports upon boot so that the system automatically redetects and reinstalls each time. Alternative options from anyone would be appreciated.
KT
 Post Posted: Tue Feb 06, 2018 8:14 pm
Ok Scott, so I went back to an image of my drive when I had first installed Windows 10. Anyway when I go in device manager and change to "view hidden devices" the LPT1 port shows up. There is a "problem" with it saying "Currently this hardware device is not connected to the computer.(Code 45) To fix this problem reconnect this hardware device to the computer.".
Now I'm thinking this is normal because no LPT device is connected to the PC. If I had something connected to the Parallel port header on the motherboard, than it would show up and not be hidden. Am I correct on this?.
 Post Posted: Tue Feb 06, 2018 9:07 pm
Ok now I disabled both again in the cmos. Restarted and everything looked good. What windows 10 did is "hide" both devices. They didn't show normally in device manager, but when I click "Show hidden devices" they both showed up.
Then what I did is shut down the pc completely and turn the switch to off in the back of the pc on the PSU.
When I turned it back on though and restarted this time the COM1 port showed with an error. "Code 10. Can not start". Of course it can't start, it's disabled!.
Jeepers!. What is going on here Scott?. No point in disabling it, if it still shows up!.
Now with the LPT1 not showing when it is enabled, that could be normal because nothing is connected to the header on the motherboard. I'm not sure though. Give me some kind of clue Scott.
 Post Posted: Tue Feb 06, 2018 9:32 pm
That appears to be a flaw in the board/BIOS design. On a correctly designed board a serial port disabled in the BIOS should not be visible to Windows. In the grand scheme of things this is pretty minor. Scott.
 Post Posted: Tue Feb 06, 2018 9:36 pm
What about the LPT port issue?. Is it normal for it to show up under hidden devices when nothing is connected to the header on the motherboard?
 Post Posted: Tue Feb 06, 2018 9:40 pm
It is normal for a BIOS enabled port to show up whether anything is connected to it or not. Scott.
 Post Posted: Tue Feb 06, 2018 10:02 pm
So do you think I should ask for an RMA replacement or maybe even get a different model board?
 Post Posted: Tue Feb 06, 2018 10:11 pm
Well for now I'm gonna ask for a replacement and wait for a response from Gigabyte.
 Post Posted: Tue Feb 06, 2018 10:19 pm
The same thing goes for the PS/2 port that I have disabled. If I look at "Hidden devices" in the device manager, Under "Standar PS/2 Keyboard" it shows under "device status": "This device is not present, is not working properly, or does not have all its drivers installed.(Code 24)"
If I look at "Microsoft PS/2 Mouse" it says the same thing.
So you are saying that these devices because they are disabled in the bios should not be visible to Windows at all?. Is that correct?.
 Post Posted: Wed Feb 07, 2018 6:38 pm
So I did a "reset my pc" through windows 10 today. Seemed to work well but changed some things around the way I didn't like it. I wanted to make sure this is a hardware problem and not software related. Same problem was happening.
After doing all that I went and installed Windows 7 Pro 64 bit. Worked well, but even with the clean install I got the same problems with the parallel and serial ports in device manager. So I just went back to an old image I made with Macrium of Windows 10. I'm just gonna do another clean install if I can get an RMA replacement of this board.
If not maybe just buy a new board that doesn't include serial and parallel port headers on the motherboard. I did a quick look at Gigabyte boards and it seems most boards have them for some reason.
 Post Posted: Wed Feb 07, 2018 7:02 pm
MSI H270 Mortar Arctic LGA1152 seems like a better board. No parallel port head, but still a serial port header. I'm still confused why you would put either of those headers on a modern motherboard.
That board should work with all my hardware I have now though. I'm thinking about getting a different cooler though. The one I have now is nice sure, but it was a pain in the butt to install and takes up a ton of room.
 Post Posted: Wed Feb 07, 2018 7:13 pm
ARCTIC COOLING Freezer 33 CO 120mm Dual Ball Dynamic Bearing Semi Passive Tower CPU Cooler looks much easier to install and handle.
 Post Posted: Wed Feb 07, 2018 7:24 pm
Another "error" I had/have with Windows 10 is with the "Hardware and Devices" troubleshooter. Running it gives an error,
"An error occurred while troubleshooting:
An unexpected error has occurred. The troubleshooting wizard can't continue.
Package ID: DeviceDiagnostic
Path: C:\WINDOWS\Diagnostics\Index\DeviceDiagnostic.xml
Error code: 0x8000FFFF
Source: Page load
User: STEVEPC\Steve
Context: Elevated "
I had tried some "fixes" on the internet that don't really work. One was saying to delete a certain registry key/keys and those keys didn't exist. Another said to make sure certain diagnostic services were running with correct start up values and they were.
When I did the "Reset this PC" the "Hardware and Devices" Troubleshooter worked though. So now I'm just back installed Windows 10 on a Macrium image I created.
If I can just get a replacement or RMA board from Gigabyte that'd be great, but I might just purchased that MSI board. Then of course do another clean install.
 Post Posted: Thu Feb 08, 2018 11:24 am
I definitely want this board!. I like how the I/O shield is built in!. Maybe I'll get a new case too!.
 Post Posted: Thu Feb 08, 2018 11:29 am
That is interesting, let me know what you think if you get it. Scott.
 Post Posted: Thu Feb 08, 2018 1:22 pm
Here is a copy and paste of my correspondence with Gigabyte Support:
Question: The COM and Serial ports are enabled in the bios. They work initially when I make a change to bios/cmos. However if I shut off my pc completely and turn it back on with both enabled then the COM port shows up normally and the LPT port disappears. 2/7/2018 7:09 PM
Answer:
What kind of cable do you have connected onto the port on the board?
If there are no input on the header off the board, the port will not be activated.
 Post Posted: Fri Feb 09, 2018 3:16 pm
Source: Page load
User: STEVEPC\Steve
Context: Elevated "
Ok I've fixed this error permanently by going into device manager, clicking on "show hidden devices" and deleting the "extra" devices or any devices that are no longer in use. Now the troubleshooter works.
 Post Posted: Fri Feb 09, 2018 3:22 pm
Also going into device manager and clicking "Show hidden devices" and deleting the LPT port seems to have fixed the problem with the LPT port. Now with the LPT port disabled in the bios/cmos it doesn't show up in device manager even after I turn the pc completely off. By that I mean shutting down and then turning the switch to "0" on the back on the PSU. The problem still remains with the COM1 or serial port though. I have that disabled in the bios/cmos and yet it still shows up in device manager with and error, "This device cannot start. (Code 10)".
 Post Posted: Fri Feb 09, 2018 3:39 pm
Scott, do you think that replacing the CMOS battery would do any good?. I only ask because years and years ago I believe the CMOS battery kept the settings and these settings for Parallel and serial ports are legacy settings. Not that the battery should be dying because the board is less than one year old. However the problem only seems to occur AFTER the board has lost power. So for some reason once the board loses power or I completely shut down that is when windows detects the COM port even though it's disabled in the cmos set up....
 Post subject: Update and Fix!
 Post Posted: Fri Feb 09, 2018 4:48 pm
Well Scott, I have seemed to have fixed this!. I was thinking about how whenever I'd make the change in the bios/cmos it would work for that period until I completely shut down. Then I thought how I have "fast boot" enabled in Windows 10 and also have an option called "Ultra Fast Boot" enabled in the cmos/bios. I know "fast boot" has been known to cause problems in windows 10 because when your pc is "shut down" it's not actually completely shut down. So I thought that "Ultra-Fast Boot" in the cmos setup must skip something or do something to increase the boot time. That might trick windows into "not understanding" somehow the change that occurred in the bios especially after a complete shut down and restart....
Anyway I disabled Ultra-Fast boot and everything seemed to work. I even went in and disabled "fast boot" in Windows 10 just to "double down" on the possible solution. Then I tested it by shutting down completely and turning the switch off at the back of the pc, and then turning the pc back on after several minutes.
Everything is working now!....Although I don't dare change those settings again!. Both parallel and serial ports are disabled in cmos and don't show up in device manager as it should be!
I made an image backup since I know things are working now. Plus I have this thread so my solution is "documented".
Post new topic Reply to topic  [ 220 posts ]  Go to page 1, 2  Next
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 6 guests
