 Post subject: Limited Connectivity
 Post Posted: Thu Aug 12, 2010 5:18 pm
Hello I have got an issue with the error Limited Or No Connectivity on a HP DV5000 Laptop.http://h20000.www2.hp.com/bizsupport/Te ... sId=499885
The network card is a RealTek RTL8139/810X Family Fast Ethernet.
The wireless interface works, for I can access the internet fully, but when I plug into the internet NIC I get the connectivity error.
I have been all over google and tried everything I have read which I will list below.
Release/Renew config
Flush DNS
Reset WInSock
Reset TCP settings
tried some XP TCP Repair tool http://www.xp-smoker.com/freeware.html
Used the Windows Network Repair tool which failed to complete.
Deleted the Nic from Device Manager and reinstalled the driver
Scanned for Viruses which found several things.
I am sure I did a few extra things but thats the just of pretty much all of it.
If this were my computer I would have done reloaded it, for it has had Limewired installed and had several viruses/malware which I found and hopefully cleaned off with SuperAntiSpyware and Malware Bytes.
Nonetheless, this is just a last bash before I reload it, I am sick of reading the same crap over and over on Google lol.
Thanks in advanced
 Post subject: Re: Limited Connectivity
 Post Posted: Thu Aug 12, 2010 5:54 pm
Reset the router also. Router works fine with other machines wireless and hardwired.
 Post Posted: Thu Aug 12, 2010 6:31 pm
Can you connect after installing a known-good network card? If that doesn't help, then can you connect after installing a temporary drive with a clean install of Windows? This will verify whether the problem is hardware or software. Scott.
 Post Posted: Thu Aug 12, 2010 6:54 pm
I do not have a USB NIC to try. Seems like I am going to need to get one of those, and add it to my tools.. for the last few issues that have really left me stumped were connectivity issues.
 Post Posted: Thu Aug 12, 2010 7:00 pm
Doing so now. Thanks will update soon.
 Post Posted: Thu Aug 12, 2010 8:02 pm
Must be a hardware issue, for a fresh load of XP on my spare drive still presented the connectivity issue. I believe I am going to advise the customer just to get a USB NIC for when they need to be hardwired, and that will also be cheaper than paying me to open this thing up.. which I reallly do not want to do.
